SOURCE: Nordictrack treadmill C2100 belk is not slipping
Several issues, drive belt that drives the walking belt could be loose but you should smell rubber if its slipping.
Something could be caught in the track causing extra drag, its easy to do if you have kids or pets
Check for when you last lubed the track and walking surface, with no silicone it will drag and bog at low speeds
SOURCE: nordictrack 1900c treadmill making a horrible loud screeching noise when turned on
I have seen the read rolled assembly roller sleeve slide off of its spindle, and.can then rub on the mounting assembly when the walking belt moves. Good luck!
