Radio Communications Logo
V Wheeler Posted on Feb 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Uniden BC200XLT scanner. How can I program it?
Tom Chichester
Level 3:
Top Expert:
  • Radio Commun... Master 62,329 Answers
  • Posted on Feb 11, 2021
Tom Chichester
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672496
Points
975369
Contact Uniden to request a manual.
5 Related Answers
Anonymous
  • Posted on Dec 30, 2008
SOURCE: programming error BCT8 Uniden
Hello.
Back to answer my own question.
I just found the problem. If you try to program one of these scanners (Uniden BCT8) and you keep getting a "pr9-loc" message every time you try to enter a frequency and "M-LOCK" is showing in the upper right corner of the display press and hold the M-Lock (E) key until it beeps twice and "M-LOCK" disappears from the display. You're now set to program.
Keith.
Anonymous
  • Posted on Jan 16, 2009
SOURCE: programming bc147xlt uniden scanner
to program the uniden bc147xlt use the manual button to select channel you want to program. punch in the desired 6 digit frequency then press E, press review to check that frequency was input correctly then use the manual button to go to next channel for programming.MAKE SURE WHEN ENTERING FREQUENCY YOU INPUT THE (.) AFTER THE FIRST 3 DIGITS FOR EXAMPLE GO TO CHANNEL 1 PRESS 149.220 E AND YOU should have no problem programming . hope this is helpful
Anonymous
  • 4 Answers
  • Posted on Feb 24, 2009
SOURCE: I have a uniden ubc73xlt handheld scanner,can't
Try a master rest:
If the scanner's display locks up or stops operating
properly, you might need to reset the scanner.
Caution: This procedure clears all the information
you have stored in the scanner. Before you reset the
scanner, try turning it off and on to see if it begins
working properly. Reset the scanner only when you
are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and CLEAR appears.
Anonymous
  • Posted on Jun 08, 2009
SOURCE: How do I Program my Uniden Bearcat BC60XLT
how do I program bc60xlt handheld scanner
Anonymous
  • 2761 Answers
  • Posted on Aug 16, 2009
SOURCE: how to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
I need a manual for a Bearcat 205XLT SCANNER
https://www.manualslib.com/manual/334326/Uniden-Bc200xlt.html
Who fixes Uniden bearcat bc200xlt in IL.
Dont know but what is problem? Really to old to fool with unless you have a parts radio. If its a battery they are avaialble on internet.
Bc 200 xlt
i don't think it can be done
I'M LOOKING TO PURCHASE AN OWNERS MANUAL FOR MY UNIDEN BC200XLT SCANNER.
No need to buy one. You can download it from this website here.
Click on the words "English PDF" on the right hand side just under the big green box.
Igot a used Uniden bc100xlt scanner and no manual and cannot rece
Go to uniden's website for literature or call small electronics shops for repairs...Most wont work on those units as they are too old. I have a uniden BC100XLT from 1988. I had to buy another one off ebay for parts. Also look for info on the BC200XLT as it was an almost identical model. Finally the batteries corrode and certain transistor pop in these early models, check the battery first. open it up and make sure the wires are still connected to battery.
BC 200 XLT
It is Q201 on the front micom board.
Read about it here or search google for the word Q201 and BC200xlt
http://www.repairfaq.org/REPAIR/F_BC_Repair.html
Any surface mount pnp transistor will work. Q202 may have a B6 on the top of it.
I had to change it on mine.
Harold
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
