l
laurdewe12 Posted on Feb 09, 2019
Model mc0952 projection clock radio. How can I set the time?
1 Related Answer
richie46
  • 12962 Answers
  • Posted on Sep 11, 2017
SOURCE: I'm looking for a manual for a memorex projection clock radio model # MC0952
Go to web site or try a google search.
Projection Clock. The time projection turns off after a few minutes.
It is difficult to answer without FULL 'make model (what it is)'. These projection clocks work in the same principle, but in two ways. The time is on a LCD film and light is shone through it, then through a lens and projected onto the ceiling. The projection light can be done in two ways;
  1. A white LED illumination light and a red LED light that comes on via an electronic timer, say 5 minutes white and then red constant
  2. or a single LED what is white or red depending on the voltage supplied to this variable voltage LED.
The only way to fix it would be to send it for repair as it is an electronic fault You could however check the manual in case there is a setting to turn off the Red LED. I had a CD Alarm Clock Radio and the projector was the first thing to fail followed by the rest of it 3 years later. I wasn't that worried as I won it in a charity raffle. My GE Alarm Clock Radio is still going strong 48 years later!
Google
make model manual
Apr 02, 2023 • Home
How to set time zones on La Crosse Projection clock 3N6
https://www.lacrossetechnology.com/support/manuals.php
3N6 its the technology named , but the model you can choose can be find on this site .
Mabe the model and page are find on these pictures.
la crosse 3n6 Google zoeken
When I set the clock, the time does not match on the projector.. how do I set the time for the projector?
Go to this page: http://www.homedics.com/soundspar-auto-set-clock-radio-with-time-projection.html
and post your question on the manufacturer page
2helpful
How do i get a manual for "emerson smart set time projection clock radio" model @cks3528 ?
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
4helpful
Emerson Research Clock w/Projection Display Not Working
You will need to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio and remove the internal battery. Let the Clock/Radio set for at least 1 hour and then put the battery back in and plug in the Clock/Radio. The functions should return to normal. If not, replace the battery (CR2430) and leave the Clock/Radio unplug for a period of hours. Then put in the new battery and and plug in the Clock/Radio to see if the functions have returned to normal. If not you may have a more serious problem with the microprocessor. You can call the Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problem.
3helpful
Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
1helpful
Sentry CR-106: setting the projector's time.
I found my manual!
To set month, press the "set" button 2 times then press "mode" to sequence month
To set date, press the "set" button 3 times then press "mode" to sequence date
To set hour, press the "set" 4 button times then press "mode" to sequence hour. (24 hour clock toggles with 12 hour clock)
To set minutes, press the "set" button 5 times then press "mode" to sequence minutes.
I hope this helps!
3answers
Sharper Image Projection US Atomic Alarm Clock (model number OQ311)
try looking up the manual on the model number you might find it online. I have the maual for this model.
Top Memorex Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
NOEL
NOEL
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
