Question about Nikon Cameras
My Nikon p900 won't focus on shutter priority
    Top Expert:
  • Nikon Master
  • 60,588 Answers
WE KNOW OF NO FIX YOU CAN DO FOR YOURSELF SORRY
Posted on Feb 11, 2019
Quack
  • 542 Answers
SOURCE: shutter priority mode?
This is directly from Epson's Product Announcement sheet: Aperture f2.0, f2.3, f2.8, f4.0, f5.6, f8.0 Automatic & manual Shutter speed Auto iris electronic control shutter and mechanical shutter flash on: 1/30 - 1/750 slowsynch & flash off: 1/2 - 1/750 manual exposure: 8 seconds - 1/750 up to 1/500 with aperture open Automatic & manual Exposure control Program auto exposure with manual +/- 2.0 exposure value adjustment (0.5/0.2 EV increments); sports, protrait & landscape modes; spot & matrix metering It's still not totally clear, but it appears to mean only fully automatic or manual.
Posted on Sep 13, 2005
SOURCE: Aperture priority not working...HELP!!
Hey Mike, This is an easy one. With the battery grip attached, you can only have either Shutter Priority or Aperture Priority work properly. You can change it with the custom function settings of the camera. So you can change it to work with Aperture Priority if you use that more so then shutter priority won't work. Brandon
Posted on Sep 30, 2007
cammedic
  • 667 Answers
SOURCE: shutter speed and apiture priority
The green rectangle is full automatic. You can use the P mode for the same function. In the P mode, you can change settings, in the green rectangle, you cannot.
Posted on Feb 14, 2008
Paul319581
  • 101 Answers
SOURCE: Camera Seems to be Locked Up
Try reseting the Cam !
Posted on Mar 10, 2008
eagle338
  • 4889 Answers
SOURCE: is there the equiv of
Yes there is. But it is called Aperture priorityAE and Shutter PriorityAE.
Please refer to page 57 of this manual(Click to download)
Sai.
Posted on Jan 09, 2010
How could use vivtar 500mm in D40x. the seller asked me to put the camera in Manaul mode and set off to the shutter priorty to off. I could not find how to set the shutter priority to off in the setting.
A 500 mm mirror lens is a fully manual lens (manual focus no aperture change) using a T mount adapter to your specific camera. The T mount costs some $15. It depends on your camera how to turn off the auto focus and go to aperture priority mode. The aperture on a mirror lens is set, usually at F8, so the shutter is the only item that can be adjusted to get a correct exposure. A digital camera (set in adjustable ASA setting) can change it's ASA to help with getting a correct exposure. Manual for digital camera are usually on the companies' web site.
Feb 22, 2014 | Vivitar 500mm 8.0 Lens Nikon D3000 D5000...
How to change the shutter speed on my nikon n65 film 35mm slr camera
In the manual and shutter-priority modes (set the dial to "M" or "S"), turn the command dial to change the shutter speed. In the aperture-priority mode (set the dial to "A"), turning the command dial changes the aperture and the camera will set the shutter speed appropriately.
If you need a manual, you may download a copy from here.
Oct 13, 2012 | Nikon N65 35mm SLR Camera
It won't take pictures sometimes. push the shutter button and nothing happens.
The Nikon D40 in Auto Focus mode will only allow the shutter to operate when the image is in focus. When looking through the viewfinder, the bottom edge provides information relative to what you are looking at. See the image below:
Item 2 is the focus indicator. It must be illuminated to allow the shutter to release. If it is not illuminated, the lens has not been able to determine the correct focus. This can happen when attempting to take a picture in low light conditions. Make sure that the front facing "focus assist lamp" on the camera (between the shutter release and lens) has not been blocked or disabled (Settings Menu # 09) and try again. Many times, you will see and or hear the lens "hunt" for proper focus - the lens will travel from one end of its focus range to the other trying to find focus. When it can't, it stops and prevents the shutter from releasing. You can get around this "unable to focus" issue by changing the position of the switch on the lens to "Manual Focus" mode, detailed below:
If a lens has an "A - M" switch, move it to "M" to manually focus. If the switch says "M/A - M " then leave on M/A (unless you're going to be taking several or more in manual mode), as these lenses may be focused manually at any time in either position. As soon as you tap the shutter button in M/A you return to autofocus.
More advanced lenses, like the 18-200mm, 70-300mm VR and 18-135mm, and any lens with an M/A position, may be focused manually at any time without moving any switches. Leave them in their A or A/M positions.
I hope this helps and good luck!
Jun 13, 2011 | Nikon D40x Digital Camera
My Nikon D200 just started locking when I depressed the shutter. It gave me the R25 reading in the view finder. If I depress the ae focus lock it fires. What is going on? Cmaclennan@verizon.net
Check your Custom Setting Menu, a1-a10:AUTOFOCUS.
Press Menu, select the Custom Menu Setting (looks like a pencil).
Select "AUTOFOCUS" and move to right.
a1 AF-C Mode Priority. Set to "Focus"
a2 AF-S Mode Priority. Default is "Focus", change this to "Release". This will enable the camera to fire anytime you press the shutter, regardless of if it's in focus or not. Use this setting if your having problems locking up, especially using some different lenses.
Try these settings. They may work for you.
Oct 08, 2009 | Nikon D200 Digital Camera with 18-200mm...
Shutter speed actomatic change
If you move from mode to mode, the camera will remember the settings from the last time you were in that mode and reset to them. This is handy if you are in shutter priority shooting sports at a high shutter speed, and then want to take a picture of something that's not moving fast, like the crowd. You just pop it into aperature priority with a remembered settings of a higher f stop.
I use this to shoot the scoreboard, which has a fairly slow refresh rate and usually comes up blank if I shoot it at a shutter speed higher than about 1/100.
Sep 02, 2009 | Nikon D300 Body Only Digital Camera
My the shutter release button isn't working
I'll give you a couple: 1. Is your mode in shutter priority or focus priority? Check your menus and go into the AF area to see which one it is. If it's in focus priority you will have to be focused on a subject before the shutter releases. The other setting is 'release priority' which will enable you to snap the shutter regardless if you're focused or not. If you tried to re-compose the picture you were trying to take, you may have locked in focus and then when you re-composed it was not in the same area thus not releasing the shutter.
2. 2 button re-set.
Jim Silva
Jun 19, 2009 | Nikon D40x Digital Camera
Pictures too dark
The settings in Auto Mode are factory set. If you want to adjust exposure and shutter speeds then you will have to shoot in Manual Mode (TV=Shutter Priority, AV=Aperture Priority, M=Full Manual)
May 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Oct 21, 2006 | Nikon F100 35mm SLR Camera
Cameras Logo
43 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
