Hit the button to start it makes the sounds like the water is entering the machine but it isn't
SOURCE: problem with frigidaire washing machine
I've read in a product review that Frigidaire put out a service bulletin regarding the electronic timer circuit board in these machines. Apparently enough of these boards failed to prompt a factory response. With this in mind, you should call an appliance repair center and ask them if they're aware of this Factory Service Bulletin. In many cases like this, where a part is manufactured defective, the repair could be free to you.
SOURCE: Rinsing cycle won't START
After all, I turned machine off with power switch, waited 30 seconds and turned it back on. It displayed "RINSING CYCLE" message, but this time went through regular rinsing cycle, then rinsed thoroughly (I counted several cups of water) and RETURNED TO NORMAL.
Halleluiah! Now I can get my morning coffee again!
SOURCE: Zanussi built in aquasave zt 685
I think I had a similar problem to this. It seems like it was starting a cycle but then it just stalled and made a buzzing noise and it did not drain properly. I opened the bottom of the dishwasher where the draining pump was located. take off the plastic cover and I found bits of broken plates were jamming the fins on the pump... Try this and see how it goes.. Hope it was of some asistance.
SOURCE: no cold water will enter machine but not water
Turn off the cold water.
Remove the cold water hose from the washer. Clean out the filter screen in the water valve. Re-attach the hose and turn the water back on. If you get no cold water replace the water valve.
SOURCE: Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
