Refrigerators Logo
Z
Zane van tonder Posted on Feb 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a whrilpool wrf40 ix all refrigerator. I believe the tempreture sensor is faulty,because it freezes up. But i don't know where it is located and how to replace it?
keith jones
Level 3:
Master:
  • Refrigerators Master 747 Answers
  • Posted on Feb 10, 2019
keith jones
Level 3:
Master:
Answers
747
Questions
Helped
314694
Points
1478
Check the defrost element before going any further
geob91
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Refrigerators Expert 128 Answers
  • Posted on Feb 09, 2019
geob91
Level 2:
Passionate:
Answers
128
Questions
0
Helped
83383
Points
414
The number you provided looks more like an item number then a model number. Please look inside the fridge and find the model sticker usually located on the inside wall either right or left top side and give us that number. whirlpool model numbers typically look like this "WRF540CWHW" and is needed to look up what you have. Digital controls usually have the sensor within the control panel but sometimes will have a rectangular box holding the sensor. if it has a mechanical knob then that knob is the sensor.
I have a whrilpool wrf40 ix all refrigerator. I be - 1396455972334-adpmdbftmufhu2y2ibiqsi3t-4-0.jpg
3 Related Answers
Anonymous
  • Posted on Jan 16, 2009
SOURCE: ECTS location
The sensor is on the left side of the engine between cyl 2 & 3. It can be removed using a deep socket or a ratcheting box end wrench. It is a pain but can be done.
deoneweb
Deon Van Vuuren
  • Posted on May 26, 2014
SOURCE: I have a whirlpool WRF40 IX all refrigerator. The ...
WHIRLPOOL WRF40 Solution to this problem!!! very easy ----I assume you have a problem with the control board switching on and of erratic when you pass setting 3 on the LED display, the designers of this fridge left the calculator at home that day, ask a technician to replace the Resistors 5, 6 & 7 (330 OHM 1/4 watt) on your electronic control board with 680 OHM 1/4 watt. This would solve the problems with this board, the LEDs will not be as bright as they were but still highly visible. Questions? [email protected]
richie46
  • 12962 Answers
  • Posted on Jun 11, 2016
SOURCE: I have a whitpool WRF40 IX. It keeps on freezing everything even on the lowest refrigeration control? Could you tell me whats wrong and if there is a part I can rrplace to rectify this?
Thermostat could be stuck on "full blast." Replace it
2answers
How do I remove front cover on Whirlpool WRF40 IX fridge. I need to access the PC board
Need full model # for proper dissemble bottom cover should just snap off
CANNOT SET TEMPERATURE
Nominal tempretures for the refrigerator side are 36-38 degrees. Nominalk tempreture for the freezer section is 0-4 degrees. Your main board that controls your entire refrigeration can be found on this diagram as 1-5 http://c.searspartsdirect.com/lis_png/PLDM/50039314-00004.png
What tempreture are you trying to achieve? By setting the unit colder you also cause the unit to work harder as well shortening the lifespan of your refrigeration compressor as well as other key parts that perform to make your unit produce cold. Some key things to look for are any type of freeze up on the rear wall of the freezer which is termed as a defrost issue and if you do have this issue message me back and I can instruct you to solve this situation. I await your reply
Thank you,
Rick
1helpful
Haier freezer and it wont freeze what should i do?
dear sir/madam
please make sure your freezer,s tempreture sensore is right location .if it,s alredy is in right location then reset the selectore swith to turn off and again turn possition.
hope answer the question.
thank you
8helpful
6answers
I have a whirlpool WRF40 ix all refrigerator. The problem is that the compressor trips at the high cooling settings (4 and 5) starts again and then trips immediately again. It only runs at 3 or lower....
1helpful
Ge refrigerator f/f side is freezing. milk and OJ are icy, vegetables freeze. my water filter burst and I suspect it's because it froze and water inside expanded. icemaker/water dispenser not functioning...
faulty thermastat or on some boxes could be sensor. if unit has a rectagular plate on back side appr. 10" x 14" look for sensor located in bottom left side of freezer. replace. if not there is a thermastat located in the fresh food side where your control knobs are. both of these possibilities are simple to change. good luck.
1helpful
2answers
I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
1helpful
3answers
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
