Question about Hitachi Audio Players & Recorders
How to preset radio stations on Hitachi AXM649U
How do I preset radio stations on Hitachi (AXM649U)
SOURCE: How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
Posted on Oct 02, 2007
SOURCE: Station preset on AWR1-1W bose radio
I found out you tune the radio to the station you want to preset, and hold the preset button (1-6) that you want to assign it to until it beeps. And it's set.
Posted on Jan 09, 2009
SOURCE: I can't preset radio stations
this is how i preset my stations, im not sure if you have done this before.
fm can save 20 stations and am can save 12
1] chose your desired station
2] press & hold the play/memory button until P01 pops up and flashes
3] to save the station, press & hold the play/memory button
if you'd like to save another station, then repeat steps 1 & 2,
then press the play/memory button again until P02 pops up,
repeat step 3.
to listen to your preset station, all you have to do is press the play/memory button.
hope this helps
Posted on Aug 18, 2009
SOURCE: Dewalt Radio won't hold presets or clock time
Replace the two AA batteries in the battery compartment.
Posted on Nov 30, 2009
SOURCE: Preset Radio Statios
I just dug out the manual and have now programmed a preset.
Instructions:
1) Make sure there are a pair of working AA batteries behind the second (inside) compartment door as these power the memory (mine were Duracells with an expiry of 2001 and had worked all the way through to 2010 before finally failing!)
2) Find the frequency you want with the Up/Down button
3) Press the M button - you will get a flashing M on screen
4) While the M is flashing, press one of the numbered preset buttons.
Posted on Apr 13, 2010
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
How do you assign preselect numbers to radio stations
You can assign radio station presets on your stock VW radio by tuning to the radio station you would like to preset, and then holding down one of the preset number buttons until the radio beeps. You will now be able to access the station by pressing the preset button.
Oct 15, 2013 | Vehicle Parts & Accessories
How do I preset different radio stations?
Hello
There are 6 preset position available for each radio band.
For programming, Radio must be ON. Tune to a station. Press MEMO/DEMO. Press any button 1 to 6. The tuned station will be memorised on the number you select by button press. Repeat using a new station and preset number. There is no atu preset option available with this device. You have to store stations you want according to your preference. Only 6 station positions for each band [total 12 positions] together with AM and FM bands.
To recall the stored stations, press the desired number 1 to 6.
Dec 07, 2011 | Sharper Image SI785 Clock Radio
How do i program the radio
Click below for the manual.
manual
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press (PRESET).
The Preset screen is displayed.
3 Rotate the Double Action encoder to select the
preset number.
4 Press and hold /ENTER for at least 2 seconds.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
A total of 18 stations can be stored in the preset memory (6 stations
for each band; FM1, FM2 and AM).
If you store a station in a preset memory which already has a station,
the current station will be cleared and replaced with the new station.
Press in the outer ring and rotate the Double Action encoder to the
left or right on the Preset screen, you can switch the Preset screen of
another band.
FM-1 FM-2 AM FM-1
You can also change the desired radio band by pressing BAND.
Hope this helps.
Zeppelinx12
Feb 25, 2011 | Alpine iDAX305 MP3USB Car Radio Car CD...
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
LG LX-M240 operating instructions: I cannot set the presets
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Stations on presets 1, 2 and 3 take longer to 'kick in' when listening to the radio
as they are the 'tens' prefix for the preset numbers. 4 - 9 'kick in' immediately.
Jul 01, 2009 | LG Audio Players & Recorders
Jan 08, 2009 | Bose Wave Radio
Radio presets?
select radio station then select which number you want to preset station to and press and hold until you hear the unit beep,also preset station will flash once aswell as the beep,station should be preset into your headunit,goodluck.
Nov 29, 2008 | Pioneer Car Audio & Video
Tuning DAB radio
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
Dec 27, 2007 | Audio Players & Recorders
23 people viewed this question
Top Hitachi Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Carlos Oliveira
Are you a Hitachi Audio Player and Recorder Expert? Answer questions, earn points and help others
