Posted on Feb 09, 2019
Left channel lower then right channel SL-1510 technics turntable
ultimate cra
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Feb 09, 2019
ultimate cra
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
3770
Points
18
Please check your headshell cartridge and the cables if you can,also try removing the headshell clean the pins.
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Dec 18, 2007
SOURCE: turntable technics sl-bd27
You have 4 wires coming from the needle pickup to the cables which connect to the amplifier/receiver. I would check the needle, the pickup unit, and the leads from the pickup to the cables. You can probably run a continuity test or ohm test for verification. If that checks, pickup and needle is your next step.
Anonymous
  • 515 Answers
  • Posted on Apr 30, 2008
SOURCE: TECHNICS SL-B280 DUST COVER W/ HINGES
All parts are discontinued for this model. The SL1200MK2 dust cover will not fit this turntable. You can actually have a dust cover made rather simply and cheaply (depending on where you live). Just take the dimensions to a PLEXIGLASS or even a GLASS shop. You can even purchase the Plexiglass yourself, cut it, and glue it together. I would suggest getting it professionally done. You can use any high impact plexiglass. Get something that is resistant to scratches and discoloring.
- DJ PRO LAB
www.DJPROLAB.com
Anonymous
  • Posted on May 21, 2008
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
Anonymous
  • 515 Answers
  • Posted on Dec 18, 2008
SOURCE: Technic Turntable repair
You can visit our Do-It-Yourself repair video site:
djprolab.com - for Technics Repairs
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Anonymous
  • 104 Answers
  • Posted on Feb 11, 2009
SOURCE: How do I change belt on a Technics linear SL -H350 turntable
http://www.archive.org/details/Turntable_Belt_Installation
above video should help. if your platter is "stuck" then call them for tips. also make sure it does NOT say "direct drive" on the front of the unit.
presuming you are talking about the SL-H350 as in the body not the SL-DZ1200 as in the title
Technics SL-1210: I'm getting tons of feedback from my mixer when the Red (Right) RCA is plugged in?
Remove the red and it goes quiet? Put the red into the left channel, what happens? Put the left plug into the right right socket, what happens? Put everything back to the feedback, power off and remove the turntable cartridge, what happens?
This proves whether it is the cable or the internal electronics of the amp, or the wiring further up to the stylus cartridge.
you are the only one with the issue
https://www.google.com/search?q=Technics+SL-1210+feedback
Technics SL-D33 Channel drop.
There's nothing wrong with the turntable then. It's your receiver that's the problem. In order to hear a magnetic cartridge it has to go via a pre-amp. It's this pre-amp that has failed in your receiver. It's only used by a turntable so wouldn't affect anything else. You should be able to trace this pre-amp by following the turntable socket wires. It will probably be a small IC that has failed. If you look up the number you should find it.
Left channel suddenly gone quiet, left channel works perfectly.
Hi, firstly switch the output rcas over on your amp/mixer and see if the problem stays in the left channel or has now gone to the right. If it stays in the left it is a problem with your amp/mixer. If it moves to the right the problem is in the turntable. Likely causes for turntable problems are cartridge being damaged or stylus damage. If you have another cartridge try that. Cheers john
Left channel not producing any sound, right side works perfectly
Disconnect the wires to the cartridge. With the amp on. Touch each wire (one at a time) with your finger. Two of the wires should buzz (1 left, 1 right) if the left doesn't buzz either the connections are faulty or the pre-amp in your amp is.
If you get a buzz on the left, replace the cartridge.
Poor sound quality from a technics SL-D210
Generally either a faulty connection to a lead or cartridge. Or a faulty Cartridge. If you switch the left and right channels of the phono leads the missing sound should move to the left and the right come to life. If it does not then there's a fault in the magnetic cartridge pre-amp in your amp.
1helpful
I have a Technics turntable Model: SL-BD22-KM, Ser.#: GF3Fc73813. The RCA and ground connection panel on the turntable has been jurked-out tearing the wires apart. I need to know which wires are soldered...
hi,
Here is the wiring of the turntable RCA plug ( RCA wire will have 4 connections like red and its outer wire then White and its outer wire.). connect these as follows.
For right channel
Red wire from the turntable to the red center wire of the RCA plug
Green wire from the turntable to the outer wire with red wire of the RCA plug
For left channel
White wire from the turntable to the white center wire of the RCA plug
Blue wire from the turntable to the outer wire with White wire of the RCA plug
OK
Need aground cable
The ground cable is usually a part of the audio cable. A red lead(right channel) and white lead(left channel) and a black lead. If there is no black lead, you can connect any wire to the metal portion of the turntable and the ground lead on your receiver. For more information, or should you have further question, please visit my website at audioserviceclinic.com. You may contact me through the website. Thank you.
One channel on my sl1200 mk 2 has very minimal sound out put. I have to turn my balance selector on my reciever almost full right to balance the volume. Any insight to this problem is...
As a test, switch the right and left RCA cables from the turntable to the amp. If the problem reverses, the issue is in the turntable or with the cables. If it stays the same, its a problem with the amp.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
