Question about Hitachi Televison & Video
I just replaced the lamp in my Hitachi 50V715 and the lamp light still blinks after I plug it back into power it up
tvtek
  • 1284 Answers
SOURCE: Replacement Lamp Hitachi 50V500
It must be a red light flashing as the 50V500 has no green lights on it. Make sure that when you place the lamp cover back on that it is activting the micro switch behind it. Otherwise the set will assume the door is open and won't ignite the lamp. Otherwise the ballast could be the issue.
Posted on Feb 02, 2007
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
SOURCE: Lamp Replacement Problems for Hitachi 50V500A
I'll tell you what I tran into and how it got resolved...
I experienced the same problem , with the blinking light...
Purchased a replacement lamp..
It didn't work(After market Universal supposably)..
Well..Come to find out.The Replacement lamp's housing looks similar, but the connecters that come out the back of the housing weren't quite long enough to trigger the microbe that activates the lamp in the Television.
Luckily I had the original lamp and it's housing that came with the television..
Took the bulb out of the new replacement lamp
Placed it in the original housing , and BINGO..It worked and is still working...
Posted on Jan 16, 2008
SOURCE: hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
Posted on Feb 10, 2009
SOURCE: hitachi tv LCD blinking red light tv wont' turn
I have hitachi lcd rear projection tv model 60v500A at first I was getting a red spot on centar of tv with in two mounths the spot got bigger. I chanched the lamp but now i don't have a picture, the red indicator on tv is now blinking.
Posted on Oct 30, 2010
I have a 50V715 purchased in 2004 no picture.
U used this tv alots?About 4 or 5 hours a day?It time to change the projection bulb,the live span of the bulb are over.
Apr 28, 2010 | Hitachi 50V715 50" Rear Projection...
When i try and turn my tv on the power light blinks blue and the fan and lamp light blinks red the everything turns off after about 30sec can i fix this myself
Hi, Does the set come on for about 30 sec.? I had a 50V715 hitachi, it came on for about 30 sec. then shut down and then it would repeat the process. After about 3 wks and alot of other pain, it turned out to be the lamp was weak. Replaced the lamp and all is great! So... it could be your lamp is going bad. Hope this is helpful.
Nov 20, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Tv power light keeps blinking wont stop tv does not come on.
Hi I don't know what model you have, but the 50v715 I have, did the same thing and it turned out to be the lamp. If the lamp has not been changed in a couple of years, its probably time to get a new one. I hope this is helpful.
Nov 10, 2009 | Hitachi Televison & Video
Tv turns on for a few seconds then the picture and sound turns off and the blue power light just blinks
It will do the same thing, until a repairman comes out, and services the TV set...
Symptom: No power / Dead Unit / Comes On and protects itself, Power LED may blink in 3 or 4 times cycles.
Cause: Check/Confirm SDR buffer ICs are not shorted, follow link to check. If so, replace affected SDR PWB.
That's what MY Hitachi service portal says...
Do you have one?
It's kinda like a crystal ball or magic carpet....not many people have one, but Hitachi techs do....
Eeenie Meenie Chili Beanie the spirits are about to speak
Nov 07, 2009 | Hitachi 51F59 51" HDTV Projection...
50v715 hitachi..the tv was on doing fine then it went off and the 2 red lights blink. What can i do to fix it?
If is the lamp and temp light on the front panel, then it could be that the bulb (lamp) needs to be replaced. Make sure you buy an original replacement lamp (phillips) they are supposed to last longer. There are also videos on you-tube that show you how to replace the lamp. Hopw this is helpful.
Nov 07, 2009 | Hitachi 50V715 50" Rear Projection...
Hitachi 50V715 power on/off problem
I would check to see if any of the fans stop turning or don't turn when set turns on. They do have sensors monitoring them and the set will shut down if they are not turning. I believe there are three fans around the chassis.
Hope this helps,
Skyassoc
Oct 23, 2009 | Hitachi 50V715 50" Rear Projection...
TV will not turn on. Lights Blink and hear noise
Have you replaced the lamp ? Make sure the door cover is closed good because there is a switch that is made when the door cover is put back on. Also you could have a bad ballast board or bad power unit board. Just a thought...... Hope this is helpful.
Oct 18, 2009 | Hitachi 50V715 50" Rear Projection...
My power shuts off on my tv
I don't know what model you have but, mine is a 50v715 and it did the same thing. It turned out it was the lamp. So you might just try changing the lamp. Hope this is helpful.
Oct 03, 2009 | Hitachi Televison & Video
Lamp light blinks after lamp replacement
I have the service manual and it shows two door switches Dr 1 is in the back of the set on rt bottom below the temp. sensor. Dr 2 is at the front panel where you open it to replace the lamp. If one of these switches are open, it would show a lamp problem. If you have a Muiltimeter and can get to the switches see if one of them is open. Hope this is helpful.
Nov 09, 2007 | Hitachi 50V715 50" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
