Question about Nortel Lands Phones
Edit delayed ring time on Nortel T7316 phone system?
We want our auto attendant to answer the phone with our menu after a certain number of rings if our reception is away from desk. We have night ringing but we don't want to turn that on every time she walks away. Thanks!
SOURCE:
SOURCE: IIncreasing the number of times the phone rings before message system answers
I have a Panasonic KX-TG5632 and I need to set the ring time, how do I set the ring time?
Posted on Jun 10, 2008
SOURCE: number of rings before answering system goes on
You can adjust the Answer Delay time by going to Menu then DTAD. Adjust the Answer Delay under this menu... 6 seconds per one ring.
If you have auto attendant set up to answer for you in a multiline system, set that delay accordingly. That will be the first system to pick up, You should set up one auto attendant for every voice line coming into your phones.
Posted on Nov 17, 2008
Vit Avaya BP
  • 211 Answers
SOURCE: Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
Posted on Apr 14, 2009
  • 52 Answers
SOURCE: auto attendent voicemail locked
Go to this phone press feature 983 this takes you to admin change mail box .The general mbox is 100 this is the mbox you want to change
Posted on Oct 09, 2009
consultel1
  • 860 Answers
SOURCE: we have nortel t7316 phones in our office. one
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only
press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Apr 16, 2010
Nortel/Norstar ICS phone system - Calls go to wrong voicemail on calls forwarded with NA
Check the forward no answer setting for number of rings on each extension that has ringing lines. The number of rings should be more than the auto attendant is set to answer with.
Nov 01, 2013 | NorStar Lands Phones
Rings twice and goes to general mailbox
Just have to go into vmail system and change the the number of rings till the vmail system answers (in this case 4); check your greeting table make sure the right one is assigned to the lines in question (each line can have a diiferent one or the same); and also make sure the right greeting is assigned to the greeting table you want to use.
Do you have a program manual? If so, it has some sample proramms that would give you a "picture" of this is done, plus flow charts.
Jan 06, 2012 | NorStar T7316E Corded Phone
Nortel T7316. We use auto assistant. Message picks up immediately. I want the receptionist to answer live and if she does not answer after a couple of rings for auto assistant message to kick in. How can I...
To change the number of rings enter Feature 983, if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant).
The 3 soft key selections GRTG, TABLE, and LINES
Press the LINES soft key
Enter the line number on the line you want to change ringing on (probably Line 1) and press OK
Press the TABLE soft key then the RINGS soft key
Press the CHNG soft key and enter in the amount of rings you wantand press OK
Press the NEXT key to go to the next line
Repeat the procedure for the remaining lines
Press Rls when finished
May 09, 2010 | Nortel T7316E 2-Line Corded Phone
We have nortel t7316 phones in our office. one
Apr 16, 2010 | NorStar T7316E Corded Phone
How do you change number of rings for the phone and auto attendant
You need to go into phone system admin programming
feature 00
left intercom
left intercom
Then the program for the ring delay on the Lines:
VMS Hunt Delay
Dial #506
Release 2.0 and earlier:
Dial 1=Immediate
2=Delayed
Release 3.0 and later:
Dial 1=Day
2=Night
Dial line number
Dial 0-6
The delay for extensions is:
VMS Cover Rings
Dial #321
Dial one digit (1-9) for the # of rings
before the call is sent to the voice messaging
3 is default
Jul 22, 2009 | Avaya ONE-X QUICK OFFICE EDITION TRUNK...
My phone won't quit ringing
Keep looking under Terminals and Sets for your extensions. Lines either Appear or Appear and Ring.
Carl
May 12, 2009 | Nortel T7316E 2-Line Corded Phone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Norstar M7310 auto attendant problem
As far as changing the # of rings, that may be your phone company. Feature 983 will get you in to change to number of rings. It goes as follows:
Feature 983
System coordinator mailbox # and password
OK
AA
Lines
Enter Line Number
OK
Table
Rings
CHNG
Enter the desired number of rings
If after changing the number of rings the Auto atendant does not pick up at all, You have to call your phone company and set up the second delay through them. We had the same problem here.
Mar 27, 2008 | NorStar Meridian M7310 Phone
Number of rings before answering system goes on
Dec 18, 2007 | Lands Phones
Lands Phones Logo
47 people viewed this question
Top Nortel Lands Phones Experts
Sanjaya Sahu
Sanjaya Sahu
deton8 von Splosion
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
