SOURCE: WS-1510-iT La Crosse Wireless Weather
My 1510-IT came with a faulty battery cover top for the rain guage. There should be a metallic clip mounted to the cover to tie the 2 batteries together electrically. Mine had nothing there. I soldered a wire between the 2 batteries and used some cardboard under the cover to make sure the batteries were pushed down into their holder. Problem solved!
I can't imagine this is systemic but it happened to me.
SOURCE: Lost my manual and cannot manage to find the menu
I found my manual so it is up and running again. Thanks
SOURCE: THE CLOCK IS ON A
Hello. Not certain what you are trying to do with the clock, so I have attached the link to the company's list of manuals. Simply select the make and model you have, and the information should help you. Failing that, the company does have a contact page, and I am certain they will be able to assist. Good luck.
If this has helped, please rate it a four thumbs up. Thank You.
http://lacrossetechnology.com/support/manuals.php
Testimonial: "spot on, many thanks"
SOURCE: Need manual for la crosse weather station model: WS - 1612 - 11
https://www.manualslib.com/manual/91064/La-Crosse-Technology-Ws-1612.html
Hi daniel knaup, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
