Question about Crown Watches
How to extract broken wind stem out of crown - Crown Watches
5 Suggested Answers
SOURCE:
escapement
  • 2338 Answers
SOURCE: i pulled on the crown and it came off the stem
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Posted on Mar 24, 2009
  • 12 Answers
SOURCE: Broken stem (or came off)
You could send it to Timex yourself and they might fix it for free if it looks like it just unscrewed.
Posted on Jun 14, 2009
  • 2501 Answers
SOURCE: the winding stem is broken can this be repaired?
It is possible to repair this but it probably needs to go back to the maker.
To locate your nearest service center go to http://www.bulova.com/brands/wittnauer/wittnauer.aspx?brand=wittnauer and click on "service center" at the head of the page.
Posted on Dec 22, 2010
ansel_albert
  • 248 Answers
SOURCE: Hello I have two nixon men's wrist watches that
just bring your watch to Nixon watch experts. they have spare and tools to repair your watch.
Posted on Jul 14, 2011
How to wind up an invicta
Unscrew the crown by turning it counter clockwise until the crown is free from the stem. Then turn it clockwise six times. After this step push the crown in and continue turning it clockwise until it is once again screwed back on to them stem. DO NOT SKIP THE LAST STEP because although the watch will operate in the winding position it no longer water proof. A simple drop of water in the stem would mean death for your watch. If you wear the watch everyday I suggest you wind it once or twice a month.
Jan 01, 2014 | Invicta Watches
Jul 14, 2011 | Watches
How do I wind up my tag carrera automatic using the crown??
Wow, how wrong yall are.
There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
Feb 24, 2011 | Tag Heuer Automatic Chronograph Series...
Does my watch have a battery or do i have to wind it? I tried winding it but it still isnt working I just want to be sure before i bring it to a repair shop. I thank you in advance. Thomas
mcdevito75 here, If you try to wind your watch listen for the distinctive click, click as you wind, if you haer this click, click then it"s a a windup, if the stem just turns without the distinctive sound click, click. then it"s a battery watch, also look for any word on the watch that says Quartz. ONE more thing, you may have a screw down cover on the winding stem, un screw the cover on the stem to get to (the crown, winding stem itself) Most likely you have to un-screw this cover on the stem to get to the actuall stem itself, Invicta makes watches like this to add waterproofing to the watch.
Nov 19, 2010 | Invicta Corduba Luminous Multifunction...
Unable to reset brietling colt, even after ajusting stem to 1st and 2nd postions.
mcdevito75 here, Let"s hope your description of the problem with your watch is wrong. Try this sequence, First, wind your watch, the automatic continues to wind your watch when you where it but to get it started, wind it 20--30 times. 2nd, your crown locks down, turn the stem Clockwise to un-lock it (the stem) now pull the stem all the way out then back in 1/2 way to set date. Set DATE to DATE before the real date turn crown counterclockwise. Now pull out crown all the way and turn clockwise to set the DATE and time (real Date) push the crown back in and turn counterclockwise to lock the crown. If this doesn"t work, look for a small watch repair shop in your area for this adjustment.
Jun 28, 2010 | Breitling Aeromarine Colt Ocean A64350...
Stem of watch won't return to its original position
The winding crown is loose on the stem. Get the stem completely out of watch and while holding in vice or pair of pliers screw the crown back on tight. Do not overscrew it, as the stem may brake. Even better would be to unscrew the crown first, dip the threaded stem end in to the Superglue and then screw the crown back. It will prevent from the same problem in future.
Rate, please.
Jul 29, 2009 | Watches
I pulled on the crown and it came off the stem
Rate me, please.
Mar 24, 2009 | Watches
Removing the crown/stem of CASIO EF-321
Other case for a simple Casio quartz watch :
Jan 15, 2009 | Casio Edifice EF106D2AV Wrist Watch
Remove the winding stem/crown.
There is a tiny point (end of small metal piece called setting lever) on the left side of the stem (on watch movement, very close where the stem is entering the movement).
You have to push that point down with a metal pin or tweezers. Crown (winder) must be pushed in to normal position otherwise you will not be able to put the stem back properly.
So, do as follows:
1) Push the crown in,
2) Lay the watch down on flat surface and push on setting lever point,
3) While holding setting lever pushed in- extract the setting lever by gently pulling crown out of watch.
Do not forget to rate, please.
Jan 09, 2009 | Fossil AM3425 Wrist Watch
Broken stem off aromen gobletover 50yrs old maker bleirristall made in bavaria.germany 24% clear stem any chance of repair have broken pieces was my Mothers passed away meens the world to me please help...
Is the stem broken near the crown? Or do you think there is enough stem to take out of crown? If not you probibly will have to go to a watchmake (NOT a watch repairman) to make you the stem. If there is enough metal to take stem out of the crown you may be able to get someone to solder the stem back together. I do that reguarly with stems that are vintage, and I don't want have the time to remake the whole stem. Let me know. Good Luck!!!!
Jul 09, 2008 | Watches
Watches Logo
61 people viewed this question
Top Crown Watches Experts
john h
Tom Chichester
Are you a Crown Watch Expert? Answer questions, earn points and help others
