Question about Casio Music
Hey, I have a Casio cps-50, does anyone know how to connect sustain pedal with it? I have attached a pedal but it does not work.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Try a different pedal. If that does not work try replacing the input jack.
Posted on Feb 11, 2019
SOURCE: Sustain pedal not working on my Yamaha P-90
What I figured out is that when i turn on the keyboard, if i hold down the pedal by accident, it will work in reverse. I dont know if this is what you mean. If it is, just dont touch the pedal when you turn it on. If it isn't, try to return the pedal. I dropped one, it had this problem, and they gave me a new one. Your cord for it might have been bent (?). Also, turn the keyboard on with the pedal already plugged in. It's not made to be plugged in while it's on. Hope this helps. - Matthew
Posted on May 15, 2009
  • 4 Answers
SOURCE: Roland DP-2 pedal not functioning correctly.
There are two types of damper pedal switches, on that is closed until you press it, and one that closes when your press it. It sounds like your Casio is expecting one type and your Roland pedal is the other type. A quick way to test this is to plug a guitar cable into the Casio pedal input and see if the keyboard sustains. If it does, then your Casio requires an "normally closed" switch.
Some pedals have a small switch near the cord or even on the bottom of the pedal that will reverse the switching operation (BOSS pedals, a division of Roland, have this feature). If you can find that, then change the switch position and you should be OK.
If not, and you feel like digging into your pedal, you could take the bottom off of the pedal and check out the switch itself. Many pedals use a switch that can be used either way. The clue will be on the switch itself. If there is an extra tab on the switch that is unused, then switch the wire that is furthest away from that tab to that tab. This will probably involve soldering, but it is nearly impossible to damage anything.
If moving the wire that is furthest away does not do anything, then try putting that wire back and switching the other one.
If your pedal does NOT have an extra tab, you're SOL, unless you want to buy a replacement switch (unsure of make). If this is the case, you are probably better off getting a different damper pedal - preferably one that is marketed as "universal"
Posted on Jul 02, 2009
  • 1138 Answers
SOURCE: Ensoniq KT-88 - sustain pedal works opposite the way it should
Usually that indicates that the polarity of the jack for the sustain pedal has been switched or someone has substituted another pedal with the wrong polarity. Try looking in the manual to see if that is an editable parameter for people who might not be able to obtain an original pedal. You may have to initialize the keyboard which is on page viii of the manual. The jacks on the back for footswitches are on page 1 and 2. The footswitch settings are on page 9. I found the manual here:http://soundprogramming.net/manuals/Ensoniq_KT-76_KT-88_Manual.pdf I don't know if you have the single footswitch or the optional stereo footswitch. If it is the single footswitch, the default setting should work correctly if it is the original SW-2 or SW-6 pedal switches. If it is the optional SW-10, the FTswL setting should be Unused. Hope this helps.
Posted on Aug 17, 2009
SOURCE: Sustain pedal on Yamaha DGX not working
Hi, I had the same problem, but I have an easy solution. I am trying to connect an FC5 to a Casio CTK-3000. The problem is open vs closed circuit in the pedal and the way that the casio interprets the info. Paulll's fix is correct, but you do not have to use soldering. Simply remove the cover, unscrew the silver screw, and you will notice that the black contraption that holds the two metal strips has one side that pops off. Pop off this side.
Now, notice that the short strip is on top and the long strip is on the bottom. The way the strips bend mean that the circuit is closed when there is no pressure on the pedal. When you press the pedal, the white knob on the long strip pushes the long strip down and breaks the connection with the short strip.
What you need to do now is remove the two strips and slide them back into the black contraption with the long strip on top and the short strip on the bottom. The white knob on the long strip should be facing up. Make sure when you do this that you hook the short strip over that little horizontal black plastic rod so that it will easily contact the long strip when the long strip is pressed down.
By bending the top (long) strip a little, you can make it so that the long strip does not touch the bottom (short) strip in the relaxed position. Make sure that the ends of the strips where the wires join do not touch each other either. You now have an open circuit in the relaxed position, which is what Casio recognizes as NO PEDAL.
Pop the side piece back on the black contraption and screw the black contraption back in place with the silver screw. Set the spring back in place and reattach the 'pedal'. Make sure that there is enough clearance between the top of the white knob and the inside of the pedal so that the circuit remains open in the relaxed position.
Now, if the two strips are NOT touching each other, when you plug it into your Casio, the Casio will not recognize the pedal, which is good. When you push on the pedal, you will close the circuit and the Casio will recognize the pedal.
If you push on the pedal and nothing happens, then the two strips are not contacting each other in the fully pressed position. Take the unit apart and try again.
If the Casio still recognizes the pedal even though you are not pushing on it, then the two strips are contacting each other at any place along their length. Take the unit apart and try again.
Enjoy your new working pedal!
Greg
PS. If you Casio won't work with your computer, there is a fix out there for that too. It involves removing (or renaming) some files that Logitech loads on to your computer when you install a webcam. Weird, but true.
Posted on Jan 27, 2010
SOURCE: Sustain Pedal Opposite Effect
I found that if I plug in the sustain pedal BEFORE turning the power on, it works fine. If I plug in the sustain pedal AFTER turning the power on, then it works in the opposite way. Probably just the design. So I would try playing with that before doing anything drastic.
Posted on May 19, 2011
Is there a sustaining pedal Casio keyboard model ctk 401
Generally, all Casio sustain pedals are compatible with all their keyboards, but i normally recomend the SP-20. SP 20 Pedals Products CASIO
Apr 22, 2016 | Pedal Music
I replaced sustain pedal jack...now sustain is on ALL the time, even with pedal unplugged
When you replaced it, you either have the wrong jack, wired it wrong or it is shorted out where you connected it. Recheck the connections.
Dec 18, 2014 | Casio Wk500 Wk-500 Keyboard Workstation...
Ctk-651 sustain pedal working backwards
Buy sustain pedal made for CASIO or switable model.
Pedal for Yamaha or Roland will work in reverse on a Casio.
If you cannot return for exchange, then open up and solder a different type of micro switch.
Dec 31, 2013 | Casio Keyboard Ctk-481 Ctk-631 Ctk-651
My casio privia px830 pedal doesn't sustain enough,
It could be that the electronics of the pedal are dirty, or that dirt has collected under it causing it to not depress all the way. Try taking it apart and cleaning it with a Q-tip and rubbing alcohol. Be very careful of any wires or delicate articles.
Dec 06, 2011 | Casio PX-830 BK Privia
I have a Casio CDP 200R. I recently purchased a FC4 foot pedal but it works in the reverse way. I tried switching the piano off and then plugging it in and it still does not work. Can you please let me...
You should try having the pedal connected when you turn unit on. Some pedals can be rewired to act opposite... However I believe this pedal should work with the Casio. You can open the pedal and see if you can move one wire so it works opposite. Also verify that the jack is set to the "SUS" setting per your user manual... around page E14
Sep 07, 2011 | Yamaha FC4 Piano Style Sustain Pedal
Hi. I'm Using PX330 as a midi controller that plays "Galaxy pianos" in cubase 5. I'm interested in buying a continuous sustain pedal (the one I got with the piano is an On\Off pedal). can you...
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Feb 15, 2011 | Casio Privia Keyboard Case
I just got an sp-3 sustain pedal for my casio ctk 560l keyboard but have no sound when i plug it in. How can i get it to work? I there a button i have to press or something?
Make sure you are plugging it into the place for the sustain pedal. If you happen to plug it into the audio out it may kill the sound.
Sep 29, 2010 | Casio SP3 Sustain Pedal
Is a sustain foot pedal similar to a tattoo machine pedal?
The sustain pedals have only two wires. Usually they terminate in a 1/4 inch mono plug.
yamaha USUALLY sustains when switch is closed. Roland usually sustains on a switch between the wires when the switch is open.
NO POWER should be supplied BY the sustain pedal... it is ONLY a switch.
Apr 19, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Casio 1600 sustain pedal problem
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
Aug 25, 2008 | Casio LK30 Note Lighted Keyboard
Music Logo
Top Casio Music Experts
Ben Armstrong
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Casio Music Expert? Answer questions, earn points and help others
