Question about Lowrance Boating
Hi there. Does anybody knows the “root” password to acces the LOWRANCE HDS internal files via Fttp server?
    Top Expert:
  • Lowrance Master
  • 30,077 Answers
It would be inappropriate to comment on a public forum.
Posted on Feb 08, 2019
  • Vladimir Feb 08, 2019
    You wold contact me by e mail: belov122@rambler.ru
SOURCE:
SOURCE: Transducer for LOwrance HDS-5
is the HST-DFSBL lowrence transduser combatible whith HDS-5 unit?
Posted on Jun 06, 2009
SOURCE: Lowrance HDS-5 won't load Navionics
You may just need to update the softwear on the GPS, you can download it directly from Lowrance.com along with instructions on how to install it.
Posted on Jul 17, 2009
fishdoctorfi
  • 178 Answers
SOURCE: Can I use my existing transducer(1000 watt tilted
As long as the connection is the same.....maybe. The difference will be the angle of beam from boat to bottom. May not cover the same area...or you could loose zoom etc. something will be different.
Posted on Dec 27, 2009
  • 32 Answers
SOURCE: Root Password
Hi Daniel,
Ubuntu has the root account locked by default. If you need to run as root, you use sudo username (This is recommended)
If you want to have a root shell on an Ubuntu system (It is not suggestedsuggested)
sudo -i
This is equivalent to the "su -" command sudo -s
This is equivalent to the "su" command
Posted on Jun 24, 2010
Editor925
  • 285 Answers
SOURCE: How does my Lowrance HDS-5
To connect a LRA 2400 to a Lowrance HDS-5 sounder/chartplotter, you can run an ethernet RJ45 cable from your Radar Processing box to the HDS-5 unit. You will need an adaptor cable for the RJ 45 cable to hook into the HDS-5 head unit. This is part no 000-0127-56.
As for the different transducer pinouts, I am not sure what transducer you have now so I cannot say if there is any kind of converter plug available, however, the HDS-5 units do seem to run best using the transducers that are made for them. Your best option may be to buy the transducer that is made for them, and this will directly connect to the display unit.
Hope that helps!
Posted on Mar 11, 2011
I need a map chip & onwers manual for a Lowrance HDS 5 like insight. Serial no. 102574610. Where can I get them?
here is the manual
HDS-5, HDS-7, HDS-5m & HDS-7m - Lowrance
https://www.lowrance.com/.../Lowrance.../HDS-5-7-5M-7M_OM_EN_988-10041-00...Sonar references do not apply to the HDS-5m and HDS-7m GPS only units. Manual Conventions. When you are instructed to press a button in this manual, the ..
Software Upgrades here
Lowrance HDS 5 Software Google Search
and finally Mapping
mapping for Lowrance HDS 5 Google Search
and specifically, INSIGHT
Insight Genesis - Download free Lake, River and Coastal Maps
https://gofreemarine.com/insight-genesis/Make your own maps and download free maps from the community. Insight Genesis' cloud-based software does all the work, automatically processing ... with sonar signals from your existing Lowrance, Simrad or B&G transducer. ... The cloud automatically backs up all your data, protecting against lost or damaged SD cards.
Jun 26, 2017 | Lowrance Boating
Hi. I"ve got a brand new elite 5hdi and been on for about 1 hour. does not want to lock in. import it from the states to Mozambique. please help
Hi Pieter
The problem here is that the unit has no idea where it is on the planet.
I think your best bet would be to reset the unit to factory defaults (page 11 of the owner's manual) and THEN use the setup wizard (page 6) to reinitialize the device.
Link to owner's manual provided below in case you or anyone else requires it.
Hope this helps and good luck!
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5_HDI_OM_EN_988-10518-001_w.pdf
Mar 03, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
If I get a new Lowrance GPS, can I use my SD card from my ifinder Hunt in the new device and use all my saved points?
First use "add gps" and add the original unit and the H20
use "receive from gps" to call in the original waypoint file from your sd card
use "send to gps" to save the new waypoint file to the sd card
remember that the original gps file may contain more waypoints than the H20 can hold so you may have to delete some waypoints from the file while in EasyGPS
if this is not clear enough, let me know and I will try again. I use the program all the time.
I just realized I left something out. EASYgps does not like the Lowrance HDS File version so an extra step is required if you are transferring files from an HDS to an IFinder. Save your HDS waypoints as Version 3 to the SD card and EASYgps will accept them
Oct 21, 2013 | Lowrance iFINDER GPS
How can I learn more about using my debth finder. Its new to me . Any video tutorials or materials I can read or watch?
look under support
http://www.lowrance.com/Products/Marine/HDS-High-Definition-System/HDS-5-FishfinderGPS-Chartplotter/
Feb 08, 2011 | Lowrance HDS 5 Fishfinder GPS Chart...
I own a lowrance hds 7 and it doesn't power on. Have any ideas what to do? Where to send for repair?
Test your Lowrance HDS 7 on different power sources e.g. on another motorboat to find out whether this is the problem of the boat's power supply or the HDS 7 itself - this advice will only help you to determine whether to call the boat-repairman or the lowrance hds 7 seller warranty service.
Jan 08, 2011 | Lowrance HDS-8 GPS Receiver
May 24, 2009 | Lowrance Hds-5 GPS Receiver
You need to wait for a fix from Lowrance on the HDS units. Supposedly, a new software update is planned for May 15th 2009 to address this.
May 05, 2009 | GPS
Boating Logo
69 people viewed this question
Top Lowrance Boating Experts
Ekse
Bob Peloquin
Level 1 Expert
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
