I have reset and everything it tells me connected but when I go to use app it wil not show video keeps telling me can not connect unstable internet
Hi, you can call on this number and discuss your problem with apple customer care. I leave a link you can follow that for more information Apple Customer Service Phone Number +1-877-717-8111. link is https://bit.ly/2P5lXNm
SOURCE: how can i connect my internet with my n70 to my laptop
check whether u install ur pc suite properly or not.follow these steps.
1)connect ur data cable to ur phone and laptop .
2)a icon shows connecting of ur phone
3)click pc suite icon on ur laptop .the click connect to internet.click on settings change ur operator according to ur sim card.
SOURCE: Unable to connect ipod touch to home network
Sounds like an I.P. problem. If set to "Dynamic", try "Static" IP. Had a similar problem with my Linksys wireless camera. It worked...than it didn't. Sounds eerily similar.
Mike
SOURCE: cant connect my ps3 psp go to the internet using
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. PS3,and PSP use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
SOURCE: the Netflix app on my
I had the same problem with my Vizio XVT473SV. I couldn't find the Netflix Activation Code. When I clicked on the Netflix App, the TV would ask me if I wanted to connect to Netflix, then it would ask me if I was a Netflix member. After clicking yes to both, it would tell me it couldn't connect to the Netflix server, check with Netflix.com/tvhelp. After a couple hours of troubleshooting, the solution was......your first use of the Netflix App has to be via the Ethernet Port/Cable. This will give you a screen with the Activation Code, after you activate the code in your Netflix account, you can go back to using WiFi on your Vizio TV to connect to Netflix. Step by step instructions are...
1) Exit the Vizio Netflix App.
2) Physically connect an Ethernet cable to your broadband (just temporarily)
3) Check to make sure the Vizio is using the Ethernet port and not your WiFi (Apps Button - HDTV Settings - Network...may have to reboot the TV to get Ethernet port connection)
4) Start the Vizio Netflix App
5) Click OK to start the Netflix App
6) You should now see a different screen that gives you the Netflix Activation Code.
7) On your Computer, Login in to Netflix,
8) Click on "Your Account & Help" link on upper right corner
9) Scroll down to Watching Instantly on your TV or Computer section
10) Click on Activate a Netflix Ready Device
11) Enter the Activation Code shown on your Vizio TV and click Activate
12) Once your Netflix account (on your computer) shows it is active, your Vizio TV will automatically log in. You should see your Instant Queue.
13) Exit the Netflix App, unplug the Ethernet cable, Turn Off your Vizio TV.
14) After 20 seconds or so (remember the TV is software driven), turn the TV back on and your WiFi should connect again.
15) Use your Netflix App and this time it should automatically connect via WiFi
note: just make sure that your wireless DSL/Cable Modem or Wireless Router is not blocking your WiFi connection request from the Vizio. You can check the connection status in the modem/router or in the Vizio in the HDTV Settings - Network.
SOURCE: I have a problem with my internet settings. I
You have to go to your internet connection settings on the Wii, and load the user agreements, accept them, and connect to your wireless internet.
Testimonial: "Thanks"
