SOURCE: stops after printing 1 job
A reboot likely fixed this problem already, or at least freed up the corrupted print job enough to be able to delete it out of queue.
However, if this is a reocurring problem, a corrupted printer driver could be the cause. Try reinstalling the drivers.
SOURCE: I am getting a 5mm dark bar on the lead edge of a print job
try drum refresh and developer refresh... make sure your firmware is current... if possible reset your print card... physically and software wise... make sure that the guides on your paper trays are a good fit... change the default paper tray for print jobs and see if that helps... if it does... then its the tray... if not then call service...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: Printer 966. Deleting Print Job stuck in Que
Sounds like a problem with the spooler.
Try to bypass the spooler when printing by right clicking on your printer and select "properties"
Select the "advanced" tab and select "print directly to the printer".
Hoepfully this should take care of it.
SOURCE: i'm trying to delete a print job and the job will
Try turning off BOTH the printer and computer and unplugging the printer from the PC. Reboot PC and printer, then plug the printer to the PC. This should delete any remaining print jobs.
SOURCE: I cannot unsubscripe
report it as spam! your email should filter to spam folder! make sure u unlilike on social media (facebook, twitter.....)
