Question about Pramac Electrical Supplies
I have pramac ac- 01 it running 1 mit after shoving dynamo alarm then engine stop
    Top Expert:
  • 6,815 Answers
Website reliablestore it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
Posted on Feb 08, 2019
2 Suggested Answers
SOURCE:
SOURCE: ac on 01 eclipse
Not sure about the ac/radio issue, although others have posted solutions for models later than yours. The oil leaking issue is more than likely a broken or cracked gasket where the pistons of the engine are located. May want to take it to a certified mechanic to get them replaced. Not a very expensive job on a 4-cylinder car. May also want to check the draining bolt where the oil is changed and the oil filter.
Posted on Jul 23, 2008
MY PROBLEM IN MY MIT LANCER 2010 IS, WHEN I STARTED THE ENGINE FOR THE FIRST TIME, LET SAY IN THE MORNING, BOTH FANS WILL WORK BUT AFTER SOMETIME, AC FAN/BLOWER WOULD STOP AND NEVER WORK AGAIN
i read that ur problem is with a Mitsubishi lancer, and not an f-150. or u r question reflects sumthing else. nun the less :mit lancer ac fan is governed by a thermal shut off. if u use it it will run, if not it will shutoff. NOW: f150?? relays r in the box under the dashboard driver side. chk fuses first,cuz relays r tough to git at.lol!
Apr 06, 2014 | 2004 Ford F150
Water leak around the control arm to ac on 02 Mits Galant?
Water dripping onto the ground when the ac is running is normal.
Are you saying the engine dies when you turn the ac off ?
Jul 24, 2012 | 2002 Mitsubishi Galant
My 1000kva cummins generator shuts down during operation indicating low voltage. what is the cause
Check for floating debris in fuel tank possibly restricting fuel flow thru screen on bottom of fuel pickup;
Sep 17, 2017 | Pramac Electrical Supplies
I do not have a beeper for my 2000 mits diamante but my front lights on the car continues to flash as if there was a alarm or if there is, it continues to be set off. How do I get the lights to stop...
1: insert the key into the drivers door key hole and turn it to unlock the door. this should disable the factory alarm 2: if the the alarm is aftermarket then sick ur head under the dash and find the aftermarket alarm and unplug it. it will look like a small plack box about the sixe of a box of matches.
Aug 25, 2011 | 2000 Mitsubishi Diamante
Genset does not start , alarm can't reset
what safety caused the alarm. if you cant restart it, it may be cause the problem that originally shut the engine down has not been fixed, it could be water level, low oil, high water temp, low fuel,over voltage, all of the above are probably run through the safeties. over volt, and water temp would probably clear its self after it sat a while. try turning off power to panel. for a couple minutes and see if it will reset, if not check water level. and oil levels
Aug 12, 2011 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Hallo wie kann man die uhr bedienen
  • Ich nehme an, Sie haben die Cobra 2000 als das ist die einzige Cobra-Modell mit einer Uhr auf.
Um die Uhr auf sie diesen Schritten folgen -
Time Set - 3 Switches (zur Zeit eingestellt) Dynaalert - 3 Switches (zur Alarm-und Radio) Counter / Clock - 3 Switches (zur Anzeige auswählen)
TIME SET Time Set Switch - Drücken Sie diesen Schalter mit Stunden-Schalter oder Minute-Schalter zur Einstellung der richtigen Zeit.
Stunden-Switch - Durch Drücken dieser Taste gleichzeitig mit dem Schalter auf die richtige Stunde Einstellung zu erhalten.
Minute Switch - Durch Drücken dieser Taste gleichzeitig mit der Zeit den Schalter auf den richtigen Minuten.
Dynaalert (Wecker) - Depressing thr Schalter auf den ersten und dann über die Zeit eingestellt VERFAHREN (nicht in Betrieb) wird Ihr Wecker gestellt. Nach dem Alarm auslösen Schalter ist so um die Uhr funktioniert normal.
Alarm Switch - Mit diesem Schalter Ursache des Alarms zu einer vorgewählten Zeit ertönt. Release-Schalter, um den Alarm abzuschalten. Alarm wird auch gehen automatisch nach 1 Minute, wenn Sie nicht mit dem Schalter Freigabe wählen.
Radio einschalten - Drücken des Funkschalter wird das Radio dazu führen, dass wiederum auf der vorgewählten Zeit. Drücken Sie Schalter auf Radio auszuschalten.
Counter / Tine - Ist dieser Schalter bewirkt, dass der Empfänger Frequenz angezeigt, um in den Empfangsmodus und die Sendefrequenz im Sendebetrieb gefunden werden.
Auto Switch - Ist dieser Schalter bewirkt, dass die Zeit gefunden, um in den Empfangsmodus und die Sendefrequenz im Sendebetrieb gefunden werden.
Zeit-Schalter - Mit diesem Schalter Ursache der Zeit kontinuierlich angezeigt werden.
Tony
Apr 23, 2011 | Cobra Radio Communications
Portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Mar 16, 2010 | Pramac Electrical Supplies
Ac on 01 eclipse
Jun 19, 2008 | 2001 Mitsubishi Eclipse
Electrical Supplies Logo
44 people viewed this question
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Lawrence Oravetz
wadingriver
wadingriver
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
