If it is an analog watch and the second hand moves a few time then stops and sort of twitches then the watch battery (even though new) may be bad. If not the the watch is dead and needs repair.
The battery is dead. Put a new coin battery in it.
You generally pop off the back and can see what you need.
You can even look at the instructions that came with it.
Hi Mark,
It appears to be a battery problem. Have you changed the battery recently? How have you checked the battery? I suggest you check the battery's voltage, even if it is a new, replaced battery.
You need to be sure the battery is not the problem before looking elsewhere.
Need more detail if this does not help, including the model of watch. Also how long has this problem existed, and when did you notice a change - was there a specific time/event?
mcdevito75 here, Once the battery leaks it destroys the quartz mechanism. Even if you find a replacement quartz, you"d need special Jewelers tools to remove and replace the quartz, even with that you could destroy the new quartz if you can find one. Best Bet, see a small watch repair shop in your area for a quartz replacement approx. $75.00
There is sometimes a need to re-set the watch after installing a new battery and there may be an instruction to "short battery to case" inside the watch.
Was the battery changed by a technician or yourself? If the latter, the seek the advice of a friendly local watch repairer, who may be able to sort it out for you.
I have read the instructions for a watch that looks like your (in the Amitron range) but there was no useful information given.
Make sure your new battery is not flat and on full power. Sometimes batteries are not fully charged as they discharge over the time and as they are stocked in large quantities, some of them get discharged even they are sold as brand new. When replacing battery in your watch, make sure you keep the right polarity. Plus and minus must match appropriate contacts. After replacement connect AC and plus side of the battery at once for 2-3 seconds - this will reactivate watch and you will need to set the watch manually. If you did all this and your watch don't work at all, there is some fault in watch mechanics and you have to look for watchmakers help.
It appears that the watch was malfunctioning which I thought was due to a change of battery being required.
(It was running slow and giving the wrong time - so my mother told me)
I subsequently found instructions for the watch on an internet site, changed the battery and the watch is still failing to set to the U.K. time zone therefore, I deduce that it is a failure in the watch rather than the need for a new battery or ranything I have or have not done.
when you look at the back are there three small rectangular indents
evenly spaced on the edge on the back? If so you'll need a special tool
for opening waterproof watches. the tool adjusts to fit the three
indents then press down as you turn counterclockwise. you can find the
tool on amazon.com or your local jewelry store. make sure the gasket is
in place and not damaged before screwing the back on.
here is a link to the tool http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
the type f battery will be written on the battery and you can usually find them at a drug store, hardware store or jewelry store that sells watches.
