Go into set up make sure region ok then set time and date
SOURCE: set time and date toshiba dkt2010-s
DK Programming
From Reception phone only
--(time set)DK- intercom #652 HH mm SECs redial
--(date Change)- intercom #651 yy mm dd redial
CTX Programming
--(time set)ctx-intercom #652 HH MM SEcs #
--(date change)-intercom #651 YY MM DD #
click start control panel date time language and regional settings select options to change formats of numbers dates and times you will see numbers at the top with some decimal settings .00 which can be changed
in xp
click start control panel change keyboard and other input methods
select formats then additional settings you will see a number of optional settings you can change or alter
windows 7
hope this helps
Configuring regional settings
You can adjust regional settings for number, currency, date and time formats to match those used in your country.
1. Tap Start > Settings > System > Regional Settings. 2. Tap the Region, Number, Currency, Date and Time tabs to view information for your region. Adjust any if necessary.
3. Tap OK to confirm and save.
Try this:
