Asus vivobook E203-xx (no suffix numbers)NA? computers are complex,. PC 2 years old or less. for sure when they fail. first off no symptoms stated but the word boot the screen is first as is sounds are you asking what to do, or how to do it? what to do is get it serviced, in a shop. how to do it is a long process. 1: like what does the screen do or show? all evidence here, matters. 2: it has no hdd only a eMMC: so is silent. drive. what can be wrong is 2 things, the battery inside is bad. 1: step one is remove the power pack AC' then push power button for 10 t0 30 seconds and release that, button, does PC work now, with AC pack back or not? no>? 2: have your tech test the PC with the big battery inside unplugged using AC pack power only work now? yes, bingo another bad battery,.
Couple reviews on Amazon regarding not powering up again. Depending on when you purchased, could try and take advantage of the warranty, but it could be internal, where the charging port is damaged.
