SOURCE: Side light Red Color
Try taking and leaving the battery out overnight. Then, replace and try to turn on. If this doesn't help, try flashing your phone's software.
SOURCE: I can't overheat my GPU cause my fan isn't working
the third light is the indicator of hardware failure so you should give it to service
SOURCE: Black screen with dots but everything is fine.
this is your TV Set. it needs to be bigger and more HD than the one your using.
SOURCE: hi. someone please help need to find pulse wire,
2006 Hyundai Sonata Service Manual is available here with diagrams and instructions.
SOURCE: i have the audiobahn a1801q and it pulses like a
The amp is gone. if you have checked and double checked and it is hooked up fine. then the amp is toast. Contact the manufacturer to get a replacement if its under warranty.
