SOURCE: trunk release not working
It could probably use some penetrating lubricant once opened; don't use WD-40 as its properties are great for penetrating but not for long.
There are a number of products, most available at auto parts stores or the chain hardware stores that have more durable lubricating properties.
Now, place one hand firmly on the trunk and 'bounce' the trunk lid while you try turning the key.
It may take a few minutes until you hit it just right but I have never failed to open a stubborn trunk or hatch this way.
If it still doesn't open, you may have been lightly hit in the rear of the car (in a parking lot for example) that has minutely distorted the sheet metal where the stationary latch is mounted.
In this case, you may have to hammer (with the side of your fist) the area below the lip of the trunk while trying to turn the key.
SOURCE: Purchased a Thor Alarm with door locks and
I have this alarm / remote start / keyless entry system and I have the poorly translated installation manual. Everything in mine installed fine in my 2005 suzuki aerio (except the power locks as the manual is worthless in that area) but I have heard nothing but horror stories from others online since I installed it.
I don't recommend you install it but if you really are determined, here is what the manual says (or tried to say and I spent 4 hrs interpretting / correcting it:
8 wire harness:
-- The 4 wire connector connects to the 4 wires harness part of the 3 relays
-- The yellow connects to the yellow of the breaker relay yellow
-- yellow w/black stripe connects to the oil sensor on the motor (look for single wire connected to sensor and generally a heat shield wrap/weave, mine was blue)
-- orange connects to the brake switch on the brake pedal
-- the blue connects to the door switch /dome light trigger
12 wire harness:
-- 6 central locking wires orange, yellow, and white plus the same 3 with black stripe.. Unfortunately the manual is not clear as to where they connect. The next page of the manual shows diagrams but they mysteriously add a white stripe to all the colors and the white wires apparently become green. I suspect that orange is not likely used in most installations and for positive door lock types (the most popular), yellow goes to unlock and yellow w/ black stripe goes to lock signal and the 2 whites go to 12v+. This is only a guess so don't hold me to it.
-- black is grounded to frame
-- Red is 12v+
-- red w/ black stripe goes to power trunk release (if equipped)
-- The 2 browns go to the left and right turn signals
-- The pink goes to the alarm
Ignition switch connections
The breaker relay:
-- blue goes to the ACC ON wire
-- Cut the ignition wire and connect the 2 greens to each end
-- Yellow connects to the yellow of the 8 wire harness
The 3 relays:
-- 4 wire harness connects to the 4 wire connector of the 8 wire harness
-- the 3 reds connects to the 12v+ red of the ignition switch (or thru the firewall to the battery)
-- black connects to the ignition on the downstream side of the 2 greens of the breaker relay
-- white connects to ACC ON
-- blue connects to the starter
SOURCE: what is the wire color for the trunk release
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
SOURCE: What is the wire color for the trunk release switch on the 2002 kia sportage
sorry dealer item..don't have that here..
In the diagram, the top wire is voltage and the bottom wire is ground.
