Question about Video Cameras
Cassette compartment comes up but holder door does not open on VL-AH 15OU
SOURCE:
cpt100
  • 154 Answers
SOURCE: Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Posted on Mar 17, 2007
micromaster
  • 3614 Answers
SOURCE: cassette compartment cover blocked
have you try to open it and see for any loose spring parts.?
thanks
Posted on Apr 24, 2008
I had same problem. Cost me $200 to fix at local repair outfit.
Posted on Jun 19, 2008
SOURCE: camcorder cassette holder stuck/won't eject
Try taking the battery out...
Posted on Jun 30, 2008
  • 3 Answers
SOURCE: Sony TRV530 has cassette holder stuck half way out
Thats an interruption of the ejection process, either you push it, you were on low battery, the energy was interrupted or you leave the camera in a car and th heat/cold affects it. Try to cheat/reset the camera system: Remove the clock cell, remove the battery or ac/cord at the same time you push the eject button once. Wait for an hour. Place the clock battery. Connect the AC/Charger cord or the battery (it MUST be completely charged). The camera will reset, check out and complete the ejection.
Posted on Dec 16, 2009
How do I fix the tape holder system on my camcorder? The door won't lock, and the cassette won't get inside the compartment.
hi,
is it close without a cassette ? if so the reel sensor in the cassette compartment may be faulty. if the head drum not rotates the cassette drive will not work correctly, if so please loosen the head drum with a plastic rod or some tools like that. do not put your finger in hence sometimes will jam your finger. remember don"t touch the scanning chip of the head.
Oct 26, 2015 | Panasonic Palmcorder PV-GS12 Mini DV...
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and...
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and I've also tried it with power supply connected?
Oct 04, 2011 | Sharp VL-Z5 Mini DV Digital Camcorder
I have a Sharp ViewcamZ VL-Z900. DEW error
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
Sep 18, 2009 | Cameras
Cancorder not wrking-e007 error message
moisture in the cassette holder. Take out the cassette, leave the holder door open for a couple of hours in a dry, warm location, and it should work again.
Sep 12, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
What doe DEW mean? The "DEW" sign keeps coming on and then shutting off..
DEW sign indicates high humidity level inside the camcorder. What you experiencing has nothing to do with humidity, It is a faulty connector on a junction board. Sharp has fix for it.
Jul 12, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
DEW message keeps coming up on camera
Good Luck,
Luwangula
May 22, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
8mm Cassette mechanism fails to eject or sometimes fails to close
This camcorder is at least six years old now, and replacements are available quite cheaply vie on-line auction sites, probably at far less than the cost of repair.
Apr 05, 2017 | Sharp Viewcam VL-AH60U Hi-8 Analog...
"DEW"
Good Luck,
Luwangula
May 05, 2008 | E.Digital Sharp VL-Z7E Digital Viewcam...
Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Aug 20, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Video Cameras Logo
78 people viewed this question
Top Video Cameras Experts
Al Rush
Ekse
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
