Car Audio & Video Logo
debbie Posted on Feb 07, 2019
Red light stays on But I want cd out - Car Audio & Video
Red light constantly on, can not get player to do ANYTHING @ ALL, only RED LIGHT ON
If you wish to get some details about audio equipment and its repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Why my ps3 console dont want to work?
Go to youtube and look up how to manually take out a stuck cd. After the cd is out, the system should work fine again.
Red and green light flash
To exit demo mode
Press display twice.
1helpful
Green diagonal lines across picture on Mitsubishi WD-52725 TV
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
1helpful
Red light will not go Green
FIRST U CONFORM THAT UR WEBCAM DRIVER CD HAD BEEN INSTALLED, AFTER THAT UR ADD THE WEB CAM IN UR COMPUTER....
OR
JUST OPEN THE CRTL PANEL.
AND CHOOSE THE ADD DRIVERS.
CHOOSE THE WEBCAM CD DRIVER THROUGH THE BROWSE AND INSTALL IT.
THEN REBOOT UR COMPUTER AND ADD THE WEB CAM.....
1helpful
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
JVC KD-S70R
you have a blown fuse there are 2 fuses for this unit yellow wire and red wire one of them has no power
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
