SOURCE: kodak all in one printer instalation error codes
Unfortunately, the only way to possible fix this error is to get the printhead out and reseat it. You can do that by removing the ink cartridges. Right above where the black ink cartridge was, at the top left hand corner of the printhead, if you push up towards the ceiling there should be a button that releases the printhead. You should now be able to tilt the printhead forward and pull it out of the printer. Reseat the printhead by putting it back in the printer and pushing straight back on the back wall of the printhead. It should snap into place. Replace the ink cartridges and close the printer. If the error clears, download the newest firmware from kodak.com so this never happens again.
If these steps do not clear the error however, call Kodak AiO tech support at 1800 421 6699 to get a new printhead.
SOURCE: Canon Pixma MP780 "Wrong Cartridge" Error Message
I have two Pixma 780's. After getting the "wrong cartridge" error one day when I turned it on, (I knew it was the right cartridge) I tried switching ink tanks, and the print head cartridge several times between the two printers. the problem followed the black print head cartridge, so I am guessing I need a new one. From that experience, I would recomend swithing the print cartridge if you get this error. Does anyone know how to do a reset on this machine? A Canon tech told me once, but I lost the info.
SOURCE: I am getting a message
The message indicates that the laser scanning head is defective. Lexmark calls it a printhead. Unless you want to spend a lot of money, it may not be worth fixing. A new part runs over a hundred dollars.
SOURCE: I have a lexmark prospect
Updating the firmware for your Lexmark Pro200 series will help fix this problem. You will need to get rid of the error first before you can successfully update your printer. Follow these steps:
1. Open the cover of the printer > Remove the printhead. If the printhead will not go to the center, turn off the printer and pull the printhead to the center.
2. Once you have the printhead removed, close the cover of the printer and turn on the printer.
3. It will ask you to "Open Cover to Install the Printhead". Press the Cancel (Red X) button.
4. It should take you back to the "Copy" menu.
5. Proceed with the firmware update. Just go to http://bit.ly/p205fw. There'll be more than one download for your model, try the top download first.
6. Once the firmware update is successful, reinsert the printhead by following the steps on your printer screen.
Source: There is a Problem with the Printhead
