Dakin Hardwick Posted on Feb 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Nakamichi Receiver 2, and it's been working great for years. Today it "froze." It's stuck on phono, but it's not playing anything. Any ideas?
Chickenwatt
Level 1:
Habit-Forming:
  • Contributor 18 Answers
  • Posted on Apr 19, 2019
Chickenwatt
Contributor
Level 1:
Habit-Forming:
Answers
18
Questions
Helped
97703
Points
41
Franco Dosil
Level 3:
Top Expert:
  • Nakamichi Master 10,542 Answers
Franco Dosil
Nakamichi Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
379322
Points
178965
Hello Dakin, check if you can change the entries from the control
If you manage to change, the problem can be found in the Nakamichi input change switches, you should check if they make good contact, for which you would have to disarm the front of the equipment to access the solder contacts of the switches and with a tester in the continuity position, corroborate that when pressing the button, the circuit is closed indicating the tester, condition of continuity
Good luck with the tests
Greetings Franco Dosil
Hola Dakin, fijate si puedes cambiar las entradas desde el control
remoto, si logras poder cambiar, el problema se puede encuentrar en los switch de cambio de entradas del Nakamichi, tendrias que controlar si hacen buen contacto, para lo cual tendrias que desarmar el frente del equipo para acceder a los contactos de soldadura de los switches y con un tester en la posicion de continuidad, corroborar que al pulsar el boton, se cierre el circuto indicando el tester, condicion de continuidad
Suerte con las pruebas
Saludos Franco Dosil
5 Related Answers
Anonymous
  • Posted on Apr 28, 2008
SOURCE: viewsat ultra 2000
I'm having the same problem with my all my Viewsat Ultra 2000. in our bedrooms. A constant freez-up. Now my viewsat HD 9000 in famliy room doesn't freez-up. Please anyone can suggest anything . Other then telling me to ditch it Lol.
A
Anonymous
  • Posted on May 02, 2008
SOURCE: Nakamichi receiver AV500
Did you make sure your Speaker A or B switch is pushed in? This happened to me a few times where I thought the receiver was broke, but someone had accidentally turned of the speaker A switch...
Anonymous
  • 47 Answers
  • Posted on Jun 26, 2008
SOURCE: Nakamichi TA-4A receiver no sound
HAI,AMP WORKS FINE , CONNACT ANY OTHER TO AMP(CD,DVD,COMPUTER,MOBILE,TV) IN BACKSIDE INAUDIO OR PRE_AMP .THEN SELECT  PLAYER TO IN MODE YOU HAVE INSAERTED.THE SOUND IS OK
A
Anonymous
  • Posted on Jul 22, 2008
SOURCE: Nakamichi R 1 receiver
My owner's manual is long lost, what do you need to know?
I don't know what problem you have, but mine, which Iv'e had since circa 1988, suddenly developed a failrly loud whistle from the speakers. I opened it for a looksee, and by chance spotted a dry joint on teh PCB. It had never been soldered properly. After soldiring that joint, the whistle is gone.....
Lukas
Anonymous
  • 104 Answers
  • Posted on Apr 17, 2009
SOURCE: Connect a phonograph turntable to a receiver w/o phono connection
you will need a little box called a pre-amp. This hooks up between the turntable and newer receivers without a phono input. A basic explaination & drawing of this type of setup can be found here
http://www.turntableneedles.com/Pre-Amps_c_4.html
I have a NAD 1600 receiver for 40 years. It always worked fine!! I just moved it 15 feet to new room and volume seems stuck on high! Knob turns but volume doesn't change. What happened??
It is funny, I was just reading an article today about New Acoustic Dimension Cassette decks saying they were top of the line and equal to Nakamichi.
The most likely reason is that the volume control needs cleaning with Electrical Switch Cleaner. You would have to remove the case and look. It is worth a quick spray.
This says it has a motorized volume control.
https://www.google.com/search?q=nad+1600+receiver+volume+on+high+volume
Speaker volume is too low in my turntable setup. How can I fix it?
remove rca plugs from speaker wires and wire the speakers to speaker connections on the back of receiver. The receiver may already have a phono input for a turntable.
2helpful
I have a ten year old bose wave/radio/cd player. Sound is great but want to play music from my ipod through the bose. my ipod plays in car using aux cable but this does not have same result when...
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
1helpful
2answers
1helpful
I'm trying to program my Dish Network remote to my Nakamichi AV-8 and can't seem to make it work. I know I'm doing it correctly because I've tested it with another receiver. Any ideas on which code I...
We would be happy to help with that. Here is a list of someof the codes that we have for your Nakamichi Receiver: 671, 748, 750, and 649.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Nakamichi Receiver provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Nakamichi Receiver. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
2helpful
2answers
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Rotel PReamp, Can I directly Connect my powered speakers to the output
Based on your post, the pre-amp is doing its job. What might be the mismatch would be the powered speaker system plugged into the output of the Rotel. Depending on what the "powered speaker system" is, it might be that it is a low impedance such as those used in computers whereas the Rotel requires high impedance to be connected to its output. What could be tried is to connect a regular amp or receiver to the Rotel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
2answers
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Buzz sound when i hook my laptop up
How many years have you had this laptop? Sad to say, if it's many years, time to replace as that would be cheaper.
Top Nakamichi Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
