I have a sta-rite irrigation pump and whenever I turn on the timer, the pump trips the breaker circuit. what could be problem? The model # is DS3HF-01. I have already changed the capacitor, start pump relay, seal, and the diffuser ring because it was leaking. the strangest thing is that it was working before I fixed the leak.
Motor starting capacitor
Motor centrifugal switch
Leakage current (GFIC)
Low voltage at motor
Seized pump impeller
This could be a lot of things. You need to post the model number for better info, but it could be:
1. A capacitor in the motor is bad.
2. There is a floating voltage affecting a GFI.
3. There is a load factor on the armature.
SOURCE: Heat pump trips circuit breaker
i want to know the size of breaker to use.we are using a 30,30,30,30but it is kicking off.would a 40,40,40,40or higher be better if they sell them.
SOURCE: Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
SOURCE: Pump is not running, or it keep tripped the circuit breaker
If it hums, and there is no water moving then you could have a bad starting capacitor, but if the motor is old, and has been running louder than usual in the recent months then it could be that the motor needs to be replaced.
SOURCE: Jura Impressa S9 Steamer trips circuit breaker
Hi
There`s probably an leakage from the steamblock, and the water flows over the contacts. This will short circuit the machine. Contact your dealer or nearest servicepartner and they will fix it with a new water connector.
SOURCE: Breaker trips when pump is turned on
make sure the amperage on the motor doesn't need more than the breaker you have. it should tell you on the name palte or the manual how many amps it uses under a workload. if it's worked before this, then maybe the motor is seizing or has a short.
