SOURCE: Foot control for PFAFF won't work
These machines need to be seen by a technician who can disassemble the motors and replace the carbon brushes. You should have them serviced at the same time since it doesn't take that much longer to do everything.
sewman7
SOURCE: Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
SOURCE: My Pfaff 7550 sewing machine will ball-up thread on underside
Make sure your tension is set on 5 and you don't have dirt stuck in your tension unit.
SOURCE: Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
SOURCE: Have a model 6091 Pfaff. The sewing foot will not lower complete
I had this same problem. On the bottom of the head there is a slide switch. Lay your machine on its back and you can easily see it. Slide it back and your problem should be solved.
