SOURCE: hooking up dvd player
You have wires hooked properly.
On your remote, hit input button, press down arrow once to AV then press right arrow button.
Then watch a DVD.
It worked for me.
Good Luck
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
SOURCE: dvd stuck in tv dvd player
According the owners manual you will have to call PROSCAN customer support for help with this problem. The telephone number for customer support is 1-888-977-6722. You can also go to The website and use the customer support there. The website for PROSCAN is www.oncorpus.com. I hope this has helped you with your problem.
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
SOURCE: no signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
