SOURCE: I have a 5 year
Lift off the rotating arm,and soak it in lime away, or crc. It's probaly has lime deposits,keeping the pressure down
SOURCE: Kenmore Upright freezer needs cleaning under bottom shelf
most of the sears freezers . lift up on the shelf that will unlock it then slide it left or right ( it may move a little hard ) that will unlock the other side , lift and remove ( one side at a time ) ... you will see its not that hard , its just hard to put it in words .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
SOURCE: need top shelf for admiral refrigerator
Click on this link to see if they have what you were looking for.
http://www.repairclinic.com/Appliance-Parts?s=t-HMG211380-%3d%3dc270
Your refrigerator stopped being built more than 6 years ago, so some items are no longer available.
SOURCE: I need to know if its safe to operate a microwave
some microwaves are able to accepa a metal object others are not.
If your microwave ever came with a rack or a temp. probe made from metal then you can add a rack,newer microwaves bounce the microwaves better than older ones,thus the ability for the microwaves to bounce better.
Older microwaves direct the microwaves to a pinpointed center of oven, so what happens when there's metal in the focus area?
It bounces straight back to the transmitter which in turn over heats.resulting in a burnt out microwave transmitter.
good luck,Gary
Please dont forget to vote this answer was helpful
Many thanks
