Thank you for your inquiry, raymond bouley!
I understand that your Frigidaire range is displaying an error code of "F13". An "F13" error code typically stands for a bad EEPROM (Erasable Programmable Memory) identification or check sum error. The best way to clear this code is to disconnect power from your range for roughly ten minutes. If you continue to experience an issue it could be a possible that you have a faulty board or wiring harness. I would then recommend having a professional out to perform a diagnosis on your range. Hope this helps. -Matt
