I haven't been able to find new hinges anywhere. Has anyone tried replacing the springs in the hinges with stronger ones?
SOURCE: Fuel tank door hinge
Found on-line at other sites.
[Removing/Repairing Gas
Filler Door Hinge: Tip from Bill Peyton] The gas door hinge will
break if pushed forward. This is usually done by moving around the car
with the door open, or by curious children. The repair job can be done
completely from the exterior.
The black plastic hinge is
held in place by four plastic rods. When pushed through the body of the
car, they expand four rubber sleeves located on the interior, thereby holding
the whole thing in place.
Remove as follows:
Open the door, and using a small
punch, push the four plastic rods through to the interior of the car. The
door will now come out. Note the position of the spring and the
hinge. Remove the spring from the old hinge, and either cut or pry our
the old hinge. This is a black plastic piece.
The ends of the new hinge are
tapered to make it easier to insert into the gas door. Clip the spring
back into place.
Now for the hard part. You will see on the new hinge
four plastic rods. These are held onto the hinge by four small
connections, all molded into a single piece. On the other side of the
hinge are four plastic “flowers” split into four pieces. You will need to
push the plastic rods through the “flowers”, once the “flowers” are pushed
through to the interior of the car. Since the rods are not free
floating, they tend to break off and fly away unless you hit them
squarely. If this happens, put a little taper in the ends, place them
back in the hold, and push them through. A punch and a hammer will be
essential. Alternatively, you can break the rods off while the piece is
off the car, insert them manually, and drive them in again with the punch.
SOURCE: 2001 Blazer door hinge pins and bushing replacement
you need a special spring compressing tool to remove and reinstall the hinge spring and then its a matter of removing the door installing the new bushing and rehang the door with new pins ive tried doing this while leaving the door on the car trust me its just harder that way good luck and please rate -jeff
SOURCE: clicking noise on door hinge
there is a plastic piece that slides in the center of the door hing if you look close it will be broke or cracked in half. That is what is causing the noise.
SOURCE: how to replace door hinge pin and bushings without a spring compr
Harbor Freight has the tool for $3.99. I just bought one last Friday and replaced my hinge pins this weekend on my 2000 Chevy Blazer. You have to get that tool. Online they are $15.00. Make sure you support the door before you take out the old pins. I just lowered the window, took rope and tied it to the garage rafters and was all set. have fun!
SOURCE: Sienna sliding door hinge replacement
I have exactly this problem on my 2004 toyota sienna. Just started happening and the door now rubs the edge of the rear quarter panel as the door opens and closes. Any help on how to replace the middle hinge would be appreciated.
The issue with those Thermador wall oven and freestanding range doors ( especially on the freestanding "professional" line ) is the weight of the door is so great, the hinge will actually move slightly over time, other times the entire hinge will need to be replaced.
This is what I'd recommend ( also official Thermador remedy, rest assured as I am a authorized factory trained Thermador service provider ) before pronouncing the hinges need replacing though.
**This does require a somewhat involved repair, so if you don't feel completely comfortable or have any reservation to trying this, please call in an local authorized Thermador ( B/S/H/ ) service provider.**
Recommendation: Adjust the door box hinge per instructions below.
1. Pull the oven away from the wall about 12".
2. Remove the hinge box cover plates.
3. Remove the vertical side trim piece. It covers one of the screws that must be loosened.
4. Loosen the 4 screws that secure the hinge box.
5. Place a rolled up dishtowel at the bottom of the door and close the door and apply light pressure to the door while re-tightening the four screws.
See fig below
6. Re-install the hinge box covers & side trims.
7. Re-install and secure the oven.
That should do it, ( or as stated, improve the situation ) if the hinges are too far gone they will need to be replaced unfortunately.
Let me know if you require further assistance or if indeed this solved your problem.
Thank you for choosing FixYa today and good luck going forward.
Regards,
Macmarkus :)
See fig below
Regards,
Macmarkus :)
