I put in the sim card which is activated
You will need to contact your service provider and verify that the SIM card is actually active. They may say it is activated but sometimes the system does not recognize it. The other thing to verify is that the SIM card is fully inserted. If you have another phone available (maybe a friend or family member) with the same company, swap their card in and see if the phone comes up with their number. It will not affect either account, but will show you if the issue is with the card or the phone.
Thanks a bunch for responding. I got the issue resolved.
Follow the above tips, otherwise,
Check for sim activation using another mobile,
Check proper network selection,
Check preferred network.
That's all, it will solve your problem
SOURCE: My Nokia 3250 in "offline" mode.
The problem is with the sim card. try to remove the sim, clean it with a dry cloth and put it back in. if the problem is not solved, take back the sim to your network provider and get a replacement, asuming the sim is damaged
SOURCE: Sidekick Lx connection down and phone says emergency calls only
do you have sevice..can you call out?
SOURCE: HTC Tilt (Trouble Reading SIM Card)
I posted a little too early. There was one other trick I've used and I guess I should have started with that. The problem is indeed related to the SIM not getting enough downward pressure on the contacts to be recognized.
So I took a small strip of paper, about 3/8" by 1 1/4". I folded it three times. When you fold it one end will be closed and the other end will have the two edges of the paper that can open up. Using the open end will make it harder to slide under the bracket. So you will want to take the closed end and gently side it above the SIM card underneath the silver metal bracket that holds the SIM in place.
I used a post-it note as the paper but anything will do. It was working with just a double thickness but I wanted to be sure so I moved up to three layers. Depending on the tolerances of your phone you might be able to only do double layer and still be able to slide it in. Or you might need to go to four layers.
I hope this solves it for you.
/text for Google's indexes so others can find this: HTC Kaiser 8925, Cingular 8925, AT&T Tilt 8925, SIM Card is missing,
SOURCE: i9 phone won't recognize sim card and dial out or receive
In any other phone the shiny gold bars go face-down, but with the i9, the gold bars face up-wards.
SOURCE: my iphone isnt reading my sim card
Try replacing you sim and if you still get the same error then it is a device issue. You will need to contact your service provider for replacement options!
