Brother CP6500 Sewing Machine Logo
S
Sierra Posted on Feb 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does the f3 error mean on a cp6500 brother sewing machine?
CJ Rock
Level 3:
  • Brother Master 4,417 Answers
  • Posted on Feb 07, 2019
CJ Rock
Brother Master
Level 3:
Answers
4417
Questions
0
Helped
1642158
Points
14985
Brother sewing machine error f3
How to Fix Brother Sewing Machine Error Code F3. A: The F3 code appears when astitch selection key, stitch length adjustment key or stitch width adjustment key is stuck. Attempt to release the stuck button. Replace the key panel if you can't release the stuck key.
barrybam
Level 2:
Sergeant:
  • Expert 208 Answers
  • Posted on Feb 06, 2019
barrybam
Expert
Level 2:
Sergeant:
Answers
208
Questions
0
Helped
76640
Points
651
Https://support.brother.com/g/b/manuallist.aspx?c=ca&lang=en&prod=hf_cp6500eus&flang=English&type3=626&type2=69
It appears that all "F" error codes need a dealer service. The old standby is to unplug it and wait 30 minutes before plugging it in but don't get your hopes up.
5 Related Answers
Anonymous
  • 9 Answers
  • Posted on Jan 06, 2009
SOURCE: Brother Sewing Machine CS-100
actually e2 is the button hole lever being down. e6 means that the thread is tangled and to prevent the motor from overheating the machine automatically stops. All you have to do is re-thread the machine and take the bobbin out, untangle it and put it back in and sew. This usually works. If it keeps happening, there could be a few things wrong.
1. if you are using thick fabric your tension should be lower. normal tension is 5.
2. your machine is out of alignment. take it in to a service center, they can fix it in 5 minutes. to find a service center near you go to http://www.brother-usa.com/service/
3. your needle is old or bent and should be replaced.
4. Your needle is too thick, standard is 80. The thicker the fabric, the thicker the needle.
Anonymous
  • Posted on Aug 03, 2009
SOURCE: manual from brother listed sewing machine
I believe these are the UL code and serial number. If there is a display band of decorative stitches on the front of your machine look on the bottom right of that panel. If the number there is a VX-920 there is no manual available for it BUT you can use the manual from the VX 970 which IS available. Do a search for that model manual in Spanish and you should find one.
ken dourof
  • 980 Answers
  • Posted on Nov 04, 2009
SOURCE: brother sewing machine circuit board is out need new one
If you have any problems with sewing machines with electronic boards or if the machine is computerised it is wise to take it to a specialist for repair.
Anonymous
  • Posted on Mar 26, 2010
SOURCE: F2 error on brother sewing machine..what does it
On mine this means the button for reverse is stuck. Just wiggle the button a bit and it will pop out again. It can get pushed in at a slight angle and catch a bit, but nothing is broken... I don't know if this is the only thing F2 means, but it is one thing!
Anonymous
  • Posted on Jul 12, 2010
SOURCE: on a brother cs-600i sewing machine, what does the
what does code E6 mean and how can i fix it?
Good afternoon, My Brother sewing mach. has a error of f7 what does this mean. The model is Cs80
According to http://www.sewingmachinesplus.com/brother-sewing-machine-error-code-f7.php
the meaning and answers are as follows...
Q: What does F7 error message mean?
A: Speed VR disconnected
Q: How to fix F7 error message?
A: Unplug the sewing machine and reconnect any loose wires on the SSVR PCB assembly and the main PCB assembly. If the wiring connections are okay, replace the SSVR PCB assembly. If the problem persists, replace the main PCB assembly.
2answers
My Brother SE-270D shows error F04 in screen
http://www.sewingmachinesplus.com/brother-sewing-machine-error-codes.php
F3 Error message
contact brother sewing machine customer service about the error
Brother XR-9000 starts with the code F1, F2 or F3 random. How can I reset this to get to a sewing mode?
The F codes are all "machine malfunction codes" that mean take it in to the shop. Random displays says to me that it's probably got an upset circuit board or chip.
Stitches loose on back of a fabric
sounds like a top tension problem. give the tensioner a good clean especially between discs first before going any further.
Looking to tune up brother CP 6500. Squeaking And skipping occasional stitches. What grease to use and where to apply grease?
No grease please, only quality sewing machine oil. Some machines marked the oil positions with red. Small holes. Else take the top and left side covers of and use just a drop of oil where moving parts are joint. Here too you should find small holes that need a drop now and then.
1helpful
Engine revs but doesn't sew
then the machine needs to be taken back and get another one
5helpful
E1 error code.
The pressure foot was up instead of down when I tried to run the machine without sewing something.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
