Its happen to two
If element still heats up then only the bulb needs to be replaced. "https://www.6ya.com/philip_b05beb373d913f26"
SOURCE: Weller model 550PK heavy-duty soldering gun is slow to heat up
It depends on what you say is slow, I have used weller soldering guns and desoldering guns for about 30 years. They come up to top heat in about 3min. If it is taking longer than that then there is a problem with the heating unit. You can call weller tech help number, should be on iron base and they can tell you how to test the heat unit.
SOURCE: Weller 8200 100/140W replacement light bulb?
The bulb's part number is 7333. You can order a replacement bulb here for about $2.50 :http://www.e-sonic.com/aboutus/cat/S/soldering%206.pdf
Testimonial: "Thank you. Bulb voltage is actually whay I was looking for but I did not specifically ask for this.:-) Perhaps a 7333 bulb is a universal #."
SOURCE: weller soldering gun replacement light bulbs
that takes a common 6volt screw in type bulb you can buy at most radio shacks or parts stores
SOURCE: TRYING TO GET SOMEONE TO REPAIR A WELLER SOLDERING GUN
Try tightening the screws that hold the copper element, light corrsion can develop and make a resistance.This can cause the gun to over heat.
SOURCE: I have a couple of
Howdy, here is a solid vendor of weller parts and accessories who has the bulbs you are looking for.
http://www.all-spec.com/search?f=r&x=25&i=2&keywords= 8200
I hope you find this handy:)
farmerbear at FixYa.com
