SOURCE: Bowflex Treadclimber tc 1000 turns off
Problem could be low colant, water pump, fan not kicking on (bad sen or bad fan motor) radiator dirty,
so the Treadclimber not working properly.
I hope this helps u
Thanks for using FixYa.
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS”
or “err OS” is displayed
Calibration Re-calibrate machine using Owner’s Manual
calibration procedure.
Speed sensor 1. Cycle power off and on.
2. Put the machine in calibration mode (see Calibration
procedure in Owner’s Manual) but do not
start the calibration routine.
3. Remove right rear plastic cover to view LED
diagnostics on control board.
Caution: Machine is on. Current is active!!
4. Locate LED D on the motor controller board.
LED may be lit or unlit.
5. Manually advance the treadle with your foot,
and check if LED D is blinking.
6. If LED D is not blinking, then the speed sensor
is not supplying a signal. Check that the speed
sensor wire is plugged into the motor controller
board, to the connection labeled “P1”. Check
connection of speed sensor to jumper wire.
Check speed sensor adjustment (use business
card to set gap between sensor and pulley). If
LED D still does not flash replace sensor.
I/O cables If LED D is flashing when the belts are turning
but err LS or OS persists check connections and
for signs of visible damage to any of the three I/O
cables. If no damage, check continuity using a
multi-meter. If a multi-meter is not available contact
customer service for replacement cables
and further assistance.
Mike
SOURCE: bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
SOURCE: my bowflex treadclimber starts for abut 3sec then
The machine needs to be re-calibrated if its an L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
