Most likely one or more defrost components have failed. Defrost control / timer, defrost thermostat, defrost heater
Can often be caused by ice blocking the cold air path air from the freezer. You may not be able to see the ice buildup but it's likely to be around the evaporator fins and could be due to a blocked ice-melt drain tube.
Probably worth emptying the freezer contents into a chilly bin or well insulated box (to keep it frozen) and leaving switched off with the freezer door open for half a day to let any ice melt, then see it it has started working again. If there is lots of water in the freezer after this you might want to find the drain tube (usually comes out above the compressor motor) and clear it (plastic coated flexible spring line for hanging curtains is good for this).
SOURCE: superba kitchenaid fridge not very cold, freezer is fine
do you have any frost build up it the freezer back wall... fan blowing in freezer and in back ...condeser coils clean... if all the above is ok ...must have temp. sensor or themostate cold control problem
SOURCE: Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
SOURCE: KitchenAid Superba fridge section not cooling, freezer is cold.
You have done a good job of attempting to diagnose by process of elimination, but this is a more complex system. I have provided some links below to assist you in diagnosing your problem. Links courtesy of www.repairclinic.com.
1. Ascertain that the evaporator fan is operational. This may be controlled by the Door Switch, (No.4) and could cause the fan to be inoperable.
2. Ascertain that the Fresh Food compartment light goes off when door is closed.
3. The air diffuser may be faulty by not controlling the air flow from the freezer properly
Tip: Always maintain dual temperature control settings at equal or +/- 1 setting position.
How refrigerators work:
http://www.repairclinic.com/0088_4_3.asp
You will need to verify operation of the following components listed below:
1. Evaporator fan motor
2. Air diffuser assembly
3. Light switch for refrigerator/freezer light
4. Door switch
Click on the links to identify the parts listed
1.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di921541&PartID=921541
2.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di827263&PartID=827263
3.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di438889&PartID=438889
4.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di586519&PartID=586519
Parts breakdown diagram:
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
SOURCE: Kitchenaid Superba Side by side, refrigerator side not cooling
Assuming that your fridge is set at max thermostat setting, and still it cools to 8 degrees only. It only mean
one thing, and that is have your refrigerant level check,
and have it loaded. E-mail to us your comments.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
