Lands Phones Logo
W
William O Beeman Posted on Feb 05, 2019
Vtech CS6529 phone. I was able to register 5 handsets, but would like to register a sixth. Is there any way to do this?
5 Related Answers
Anonymous
  • Posted on Jun 01, 2007
SOURCE: Not Registered
I had the same problem and this procedure fixes it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Anonymous
  • Posted on Mar 05, 2009
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Anonymous
  • Posted on Sep 20, 2009
SOURCE: My vtech 5825 screen says NOT REGISTERED and does not work
Place the handset in the charger and press find handset for 4 seconds.This will register the handset. do the same for other handsets.
Anonymous
  • Posted on May 19, 2010
SOURCE: 5.8GHz Cordless Phone with Digital Answering System & 4 Handsets: my vtech cordless phone says connecting and i can'...
my vt phone is lock and need to unlock it help
Anonymous
  • Posted on Jul 14, 2011
SOURCE: How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Date and time not correct when listing to voice mail
Possible battery is down. Refer to page 58 of manual CS6529-4B_UM_V5_20141120.pdf (vtechphones.com) for further details.
How can I deregister a handset CS6529-4 from an old base and register it to my new base CS6529-2? (without the old base)It reads 'out of range or no power at base'.
Pages 54 & 55
https://vt.vtp-media.com/media/p/document2/products/%7BB815A560-BA3F-4D08-B965-E20E835173ED%7D/CS6719_UM_1.pdf
How do I register my vetch cordless phone?
General - Product Troubleshooting - VTech® Cordless Phones
www.vtechphones.com/support/.../35/178
VTech Communications Inc.Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger. Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds.
Product Registration - VTech® Cordless Phones
https://www.vtechphones.com/.../product-re...
VTech Communications Inc.Vtech DECT 6.0 cordless phones are among the most advanced and innovative homephones on the ... Product Registration. How do I register my product?
vtech cordless handset, how to register - YouTube
? 3:21
https://www.youtube.com/watch?v=dV9rZ_cYcks
Feb 22, 2015 - Uploaded by Brian Williams
i registered my handset but im not able to call and answer call from my ... you lose your phone you have to de register allphones and start over.
My vtech phone say not registered and see manual #cs6114
VTech Communications Inc.My handset displays Not Registered. ... If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in ...
My vtech phone says not registered and not sure why ... - Fixya
www.fixya.com/support/t10092346-vtech_phone_says_not
Aug 13, 2011 - my vtech phone says not registered and not sure why and how come? can ... See page 26 of the manual for detailed instructions on HOW TO ...
My vtech dect 6.0 phone says not registered how do i fix it ...
www.fixya.com/.../t7993579-vtech_dect_6_0_phone_says_not_registere...
Jan 26, 2011 - my vtech dect 6.0 phone says not registered how do i fix it - VtechDECT 6.0 ... If you click on the above it will take you through to the manual, hope i`ve helped .... See all Vtech DECT 6.0 Digital Cordless Phone Questions ...
? 3:21
My phone says no line plz help me. Been without a ... VTechuser manual had no instructions to set up an ...
[PDF]User's manual - Vtp-media.com
Need to set time and see my message. I do not see a menue button Model cs6529-3
The MENU button is in the upper-right corner of the keypad on the handset. See the illustration on page 8 of the manual: http://cdn-media.vtechphones.com/media/p/document2/products/%7BC22EF890-EFEF-44C3-9938-F1F353D1711C%7D/CS6529-3_UM_3.pdf
The date/time instructions are on page 13.
1helpful
2answers
Vtech Dect 6.0 says not registered. how do I register?
Instructions for registering additional new handsets on VTech Model DS6151: Place additional handset on main base. Press HOLD on main base and # on handset. Asks you to de-register. Press no. Registration of additional handset takes place.
1helpful
4helpful
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
