SOURCE: Dyson 18 slim the rotating brush bar will not
If the DC18 has a proteted belt then it will have to be replaced by a Dyson engineer or repairer. If the cleaner has a removable sole plate where the beater bar is then remove it and replace the belt - sounds like the belt has snapped and needs to be replaced. if your DC18 is still relatively new it should still be under guarantee.
SOURCE: The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
SOURCE: brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
SOURCE: Dyson DC25 Animal Cleaner Head Stays Off the Floor
I'm sorry to hear you're having difficulties with your DC25. I'm sure we can help resolve this - please give us a call free on 1-866-693-9766, or email us at [email protected] so we can provide assistance.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
