Microwave Ovens Logo
Amber Benken Posted on Feb 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE microwave smells like burning plastic - GE Microwave Ovens
Clyde Hanson
Level 2:
Sergeant:
  • Expert 221 Answers
  • Posted on Feb 06, 2019
Clyde Hanson
Expert
Level 2:
Sergeant:
Answers
221
Questions
Helped
69602
Points
609
If nothing was spilled into the vents on the back side of the unit, then some internal electric parts is going bad. There are dangerous high voltage parts inside melting themselves to ***** and it will die soon, so throw it away before you have a fire.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 11, 2007
SOURCE: buzz, plastic smell and no heat
Chances are you have a magnetron that's failing. GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. The bulletin shows you where tyo check. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touch with a local authorized servicer.
Anonymous
  • 525 Answers
  • Posted on Jun 03, 2008
SOURCE: GE Profile Spacemaker II - Burning smell and no heating
You may have a failure of the H.V. rectifier. I would recommend that a trained technician replace this part due to the high voltage potential.
cactus bob
BOB BROWER
  • 267 Answers
  • Posted on Mar 08, 2009
SOURCE: capacitor burned out? horrible burnt smell.
YOUR GOING TO NEED A NEW MICROWAVE . the cap may be bad but the real bad smell you have is most likely the HV tranformer , if the magntron shorts to ground there will be a small smell if you dont pick up on that and your microwave is set to run another few mins the transformer will overheat and burn , then the fuse blows and the controls shut down . the end result , you have more parts bad than you have good . if you google " GE SPACEMAKER MICROWAVE FIRE ' you will see your not the only one , its getting to be COMMON . good luck
Anonymous
  • 6784 Answers
  • Posted on May 29, 2009
SOURCE: MICROWAVE IS NOT HEATING
HI, the actual device that produces the heat is damaged or faulty. this device is called the Magnetron. you will need to replace this part in order to restore the heating ability of this microwave oven.
Please rate and have a great day:)
Anonymous
  • 43501 Answers
  • Posted on Aug 07, 2010
SOURCE: microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
G.E Microwave model JVM1860 Burning Smell
you must open inside see the diagram, and see 1) burn cable 2) fuse 3) diode 4) capacitor 5) magnetron 6) bulb etc.
God bless you
1helpful
We have a GE JVM1540 space saver microwave. It is less than a year old. Will not heat and immediately starts smelling like burning plastic. Any ideas as to what is causing that?
CHECK THE MICROWAVE MANUAL LOOK FOR FACTORY WARRANTY ,MUST BE A BAD COMPONENT ,IF YOU MICROWAVE IS UNDER 1 YEAR WARRANTY THE FACTORY WILL REPAIR IT AT NOT COST TO YOU..CONTACT GE FACTORY.
Our JVM1850 makes strange noises, its lights flicker, the microwaves smokes and the unit emits a burning plastic smell. This unit is only 1 1/2 years old.
Basic
Microwave Oven Troubleshooting Tips
heatman101
3helpful
Burning smell microwave
The burning smell is most likely the rectifier burning. Look for a rectanguler black thing connecting from one lead of the capacitor to ground.
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Burning smell and won't heat.
If it buzzes real loud it's probably the high volyage diode. However some times if it smells it's the transformer. Usually the diode is a cheap fix ~$10.00 but this model the diode is $50. It's number 50 on the link below. Let me know how it works out or you need anything else.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JVM1440BH01&productCategoryId=0123370&brandId=0432&modelName=MICROWAVE&diagramPageId=00001&documentId=G0312014&pop=flush
1helpful
Capacitor burned out? horrible burnt smell.
7helpful
3answers
Microwave smokes and smells like burning plastic
heatman101
GE Spacemaker XL 1400
IF THE UNIT IS STILL UNDER THE 90 DAYS BRING IT BACK TO
WHERE YOU GOT IT BEFORE IT STARTS A FIRE!!
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
