SOURCE: i got avital remote control starter and the car cant star
What kind of vehicle? And did you wire it into the alarm? If you reply with a vehicle year and model I can give you the wiring diagram.
SOURCE: Just bought a`used truck that came with a Viper
That remote can work with both a security system, and a combo unit security/starter.
Best bet is to take the vehicle and remote to your local Viper dealer and they can look the car over and tell you what was installed and help you learn how to use it.
SOURCE: avital 5303 would not work after changing the battery in the remote
be sure the polarity of a battery when you fix it in the remote unit
SOURCE: How do I stop the buzzing under my avital remote
It sounds like the positive light feed is back feeding the flasher relay.
With your remote starter, can you select negative instead and wire to the negative wire instead? If not, you can use a standard automotive relay as an inverter:
http://images.the12volt.com/12voltimages/pos2neg.gif
SOURCE: Avital remote start app. Is there any remote start app for avital remote start
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts. ..
