I have tried everything! Can get to terminal&sets but can't see system programming...
SOURCE: Norstar m7310 phone
Go to 'Setup / Feature' -> look for the menu item with option as Tone OR pulse...this is where u have to change :)
SOURCE: reset Norstar M7310 System Administration password
This works, i just did it today!!
Press Feature 985
Press the 9 Key
Enter RESETSMPSWD (73738767793) using the dialpad
Press YES
Once you have RESET the password, it reverts to the default.
See Below
If your system uses 2 digit extensions use 120000
If your system uses 3 digit extensions use 1020000
If your system uses 4 digit extensions use 10020000
SOURCE: nORSTAR m7310
To Log Into System Programming:
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
Press: NEXT Display will read: "B. General Admin"
Press: SHOW Display will read: "1. Sys speed dial"
Press: NEXT Display will read: "2. Names"
Press the SHOW Display will read: "Set names"
Press: SHOW Display will read: "Show set:__"
Enter the extension number of which you wish to change the name Display will read: "<##:name>"
Press the CHANGE softkey
Using the dial pad spell out the name Ex: If you need the letter
K press the 5 key twice and then press # to confirm the letter.
Continue until the entire first name is spelled. (note: you are limited
to 7 characters)
Press: NEXT (if you fail to do this step, the name will not be saved!!!)
Press the RLS key
Hope this helps!
SOURCE: call forwarding for NorStar m7310
You have to know how to get into programming, and it depends on the type of telephone lines you have... if you have regular analog lines, on a out bound call transfer there is going to be line degragation. Meaning that the outgoing call is not going to be of the best quality.
Secondly, you have to see how many telephone lines you have, if you have 3 analog trunks, with a call forwarding to a cell phone, you will be using up 2 lines... 1 incoming and 1 outgoing to your cell. This leaves 1 trunk for incoming or outgoing callers.
SOURCE: Norstar m7310 I would like to set more phones to ring
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
if the programming doesn't look like 1 described call me @1.410.984.4840
