I have a ProForm 400 that work but the deck is not stable. There’s a broken bracket underneath (that supports the deck). Is this a part that can be replaced or repaired?
1) LUBE the deck belt see the video 2) Lube the rollers bearing front and rear 3) test the drive belt motor and replace it 4) Deck belt worn God bless you
1) LUBE the deck belt, very well maybe the deck belt, 2) Lube the rollers bears. very well. 3) test the input voltage motor, if there are voltage , the motor need repair. God bless you
Dear Sir:1) Lube the deck belt, maybe you have a deck belt worn, and need replace.2) Test the input voltage for main motor, if there are the motor need repair or replace.3) Test the output voltage from main board for input voltage motor, if there are NOT, the board is faulty.4) See the drive belt and replace it.See my personal tips for HELPsincerely. God bless you
Dear Sir: This problem is by lack of LUBE in according with the instruction manual, proceed inmediately. RUn the software calibration for diagnose and trouble.
3) The Shut down is for protecting the electronic system components. Produce enough friction and by that reason shut down.
Should be a knob on the storage latch that pulls out of the metal shaft. Make sure you support the walking deck with your other hand so it doesn't drop suddenly.
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
When you put it in the highest setting can you see the deck actually moving in an upward direction? If not the linkage might be broken or damaged. When you raise the deck up or down with the lever it should move, a deck setting in the full up position is a pretty high setting you have to have some long grass to be cutting in the full up position and still think its to short. You might be able to reposition the deck, if when you look under the unit you see a bracket that controls the deck height setting that has a number of holes in it(maybe even 2 brackets), there should be a pin(s) in one of the holes this could be set in a low position and therefore you can change position to change height of deck.
