Exercise & Fitness Logo
John Rasmussen Posted on Feb 05, 2019
My Life fitness 95xi eliptical just shut down after a few seconds after start, and not possible to adjust resistance.
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Apr 04, 2013
SOURCE: life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
How can I turn down beeping on Life Fitness 95xi elliptical? My wife pedals slowly on it and it's constantly restarting and beeping and beeping and beeping.
To turn down or turn off the beeping on your Life Fitness 95xi elliptical, follow these steps:
  1. Locate the control panel: The control panel is usually located near the handlebars or on the console of the elliptical.
  2. Find the sound or beep settings: Look for a sound or beep option in the settings menu.
  3. Adjust the volume or turn off the beeping: Use the up and down buttons to adjust the volume of the beep, or turn off the beep completely.
  4. Save the changes: Once you have made the necessary adjustments, be sure to save the changes by pressing the "Save" or "Enter" button.
If you are unable to find the sound or beep settings, consult the owner's manual or contact the manufacturer for assistance. Keep in mind that some beeps are important safety warnings, and disabling them could be dangerous.
Life Fitness 95xi elliptical electronic panel will turn on but after a few seconds the screen goes blank and evenutally starts back at start up screen.
I would suggest verifying 6 volts output from the battery. From there, check the reed switch connection on the power control board. Also verify the gap between the reed switch and the magnet on the pulley. It needs to be close enough to the magnet to get a good reading. I am attaching a link to a video that shows the reed switch replacement procedure. You can see the magnet and also the slots in the reed switch that allow the adjustment. LifeFitness 95Xi Crosstrainer Video Reed Switch Replacement Speed Sensor
Electrical issue.
check the battery or alternator that charges it. battery is usually front end and alt is in the back. if this is not it it could be the the controller board
Where is the battery on the life fitness 95xi
The battery is located in the front of the rear drive mechanism. It is mounted just below the alternator control board. The following video shows the battery location along with the battery replacement procedure. Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
Eliptical 9500 HR lifefitness lights then stos
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Start by checking your battery for the proper voltage output. The following are some helpful videos.
Life fitness crosstrainer 9500 HR just shut down few second after start
3helpful
2answers
How to reaplce a battery on the life fitness 95 xi
u open top rear hood and you will see battery on there
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
