SOURCE: embroidery arm won't park or go in position on hoop to embroider
You may need to have the embroidery unit serviced. The slide rods in the embroidery unit will get dirty over time and must be cleaned and lubricated. If not, the mechanism can not slide freely and you will be unable to keep the unit calibrated while stitching a design.
You could attempt to disassemble and clean it yourself, but if you bring it to a repair center in pieces or improperly assemble your repair is going to cost a lot more than it will if you go today.
SOURCE: strange noise from the lever that connects the hoop to carriage
Is this where the belt would be also, because my arm bumped the wall because it did not have enough clearance and it jumps and clicks when returning to home.
[email protected] debbie
SOURCE: new screw for hoop
Any Janome dDealer will be able to order for you, just specify which hoop and machine....or take it to the shop to show them is best
