Probably two reasons for this. 1) the contacts at the base of the brush are not clean which will prevent proper charging , the low battery beep is telling you to recharge.2) the battery needs replacing.
This happened to me as well. One long, two short beeps. Incessantly. Only happens when brush is on the charger.
Try this simple fix first. Hold down the SILVER button for 5 seconds while the toothbrush is on the charging base. If the fix works, it will fix the problem immediately like magic.
If that doesn't work, try this:
1) remove brushhead.
2) use screwdriver in the base and turn 1/4 turn
3) push out assembly from the top
4) dry the inside of of the base handle. allow to air dry
5) allow the switch to air dry
6) reassemble
The best tutorial for repairing Sonicare toothbrushes is here: Repairing your Sonicare
The problem is either a corroded circuit board or worn-out Ni-Cad batteries. Both repair solutions require soldering, but full repair is possible.
