Gisele Lovence Posted on Feb 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
5501-126.01 error code in a Bizhub 4750 need assistance with this
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Oct 25, 2022
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1911191
Points
11959
A/C signal out your wall outlet or the you are using a European model machine in the US or vise versa. Also check the electrical cord
1 Related Answer
koeone21323798
Rolando Blunt
  • 42 Answers
  • Posted on May 23, 2018
SOURCE: konica minolta bizhub 4750 error says paper jam and there is no trace of paper. How I can I fix this
check evrywhere this machine has sensors check the fuser
O que posso fazer para remover o erro de codigo C-D252 na Konica Minolta C364 bizhub
English only on Fixya please. We are a North American website.
Error Code Pls help - Konica Minolta
Copytechnet https://www.copytechnet.com > ... > Konica Minolta Jun 20, 2012 - CD252 (C-D252) code at start up. Solution CAUSE: The Controller 1 setting is enabled in Tech. Rep. Mode without the IC-409 (Fiery® ...
fuser error code C252
May 7, 2014
Bizhub C451 bad print quality, no accurate color
Jun 4, 2014
Error Code Bizhub 283 with C-D272
Mar 17, 2016
error code C- D251 bizhub C451
May 19, 2009
More results from www.copytechnet.com
Konica-Minolta bizhub C452 - Error Code
Printcopy.info https://printcopy.info > model=bizhub+C452 Code: CD252; Description: No relay circuit boards for IC-412 mounting at IC-412 mount setting; Causes: MFP board (MFPB) Relay circuit boards (VI-505) .
2answers
How to fix error c-3b07 on konicaminolta bizhub c554 copier
Error message and link to service manual at the link below might be of assistance.
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20554e&code=C3B07
https://printcopy.info/?mod=srch&inmod=docs&brand=Konica-Minolta&strSearch=bizhub+554e
I have a bizhub 4750 and i need to know the service mode password to enter tech rep mode. many thanks Brad
1. Turn on your Bizhub 4750 laserjet printer and wait until it sets to normal mode.
2. Go to the Control Panel Settings on the printer.
3. Scroll down and select the Utility or Counter menu.
4. Navigate to the bottom of the screen and open the Details tab.
5.Look for a message stating [STOP][0][0][STOP][0][1]
6. Go to the Counter menu again and scroll down to the bottom.
7. Clear the cache memory under the Developer & Drums menu.
8. Connect your printer and computer over a network connection.
9. Run the F8 program from the Functions menu.
10. The service mode password will display on the screen after a while.
1helpful
I have a bizhub 4750 it has an error code 3423 121 how do i clear this error when the printer does not have a utility/counter key
You have a bad fuser unit. Its hot part that fuses the toner to the paper, so you cant wipe it off.
Try this once if the code come back DO NOT RESET again as the fuser can catch on fire that will ruin a perfectly good day!!! have a tech come out and replace the unit
(2) Procedure 1. Turn OFF the main power switch. 2. Turn the main power switch ON while pressing the Power key. 3. If a trouble code appears, press the "Menu" key on the control panel. 4. Touch the password input area and, using the keyboard on the screen, type the CE password. (The initial setting for CE password is "92729272.") 5. Touch [OK]. 6. Touch [Trouble Reset]. 7. Touch [OK] on the check screen. 8. According to the description on the screen, turn off the main power switch, and turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Bizhub pro 1050: le code error SC32-32
Draw #2 Paper feed assist fan (located in the paper guide rear is bad jammed with paper dust or burned out /Rr2 (FM23)
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
