SOURCE: machine does not recognize refilled office max cartridge (black)
sir,
try to clean the cartridge on the copper side with tissue with and alcohol maybe the contact points doesnt meet or the cartidge itself is already defective. try also use an empty good cartridge just to to determine wich cartridge is defective.
yours,
alecz
SOURCE: all the lights on my
ALL LIGHTS FLASHING MEANS THAT YOU PRINTER REQUIR ADJUSTMENT PROGRAMME FROM SERVICE CENTRE.
SOURCE: epsom dx4450 how to change ink cartridge
Replacing the cartridge:
1. Make sure the printer is on and open the printer cover
2. Make sure the printer is paused and the output tray at the front of the printer is lowered
3. Hold down the cleaning button for three seconds until the print head
moves slightly to the cartridge replacement position, and the power
light flashes when the print head is in position. Do not move the print
head by hand, it will be damaged
4. Lift up the clamp that holds the cartridge you want to replace as far as it will go.
5. The cartridge will rise partly out of the cartridge holder. For
black ink replacement, lift up only the smaller clamp on the left.
6. Lift the cartridge out of the printer and dispose of it properly.
7. Remove the cartridge from its protecting bag. Remove only the yellow
tape seal from the cartridge. The yellow tape seal must be removed.
Leaving the tape on when you install the cartridge will permanently
damage it. Do not remove the tape seal from the bottom of the
cartridge.Otherwise ink will leak.
8. Lower the ink cartridge into the cartridge holder with the label on
the cartridge face up and the arrow on the cartridge pointing to the
rear of the printer.
9. Press the ink cartridge clamp down until it locks in place. Do not press the cartridge itself.
10. Press the cleaning button. The printer moves the print head and
begins charging the ink delivery system. This process may take a few
minutes to complete. The power light continues to flash while the
printer performs the ink charging operation.
11. Never turn off the printer while this light is flashing. Doing so
can result in incomplete charging of ink. Even if you do not press the
cleaning button, the printer moves the print head and begins the ink
charging process about 60 seconds after you replace the ink cartridge.
12. When the ink charging procedure is finished, close the printer cover.
SOURCE: c66 epsom printer the 2 buttons are flashing red
unlug from the mains wait a few minutes and then power on
please leave a rating
SOURCE: lexmark e250dn printer, toner light is flashing, new cartridge
Could be photoconductor at end of life.
You shoul still be able to do a printer test print (press the arrow button).
Look on the printed pagesfor Toner AND Photoconductor.
These show as OK when new or very low count, and 100% when fully used.
If the toner is showing as 100% when you've just replaced it, either the chip is faulty, the wrong one, or if the cartridge is a remanufactured one possibly nor been replaced.
