4 stroke 2005 Yamaha 15 hp leaks engine oil out of a small hole just above the exhaust hole only while running. about 1/4 liter per 3 hours. @
SOURCE: exhaust gets red
could b obstruction in exhaust put hand couple of inches behind exhaust and rev it up should have good amount of exhaus coming out.if it is no obstruction there check timing
SOURCE: BMW X3 2.5si M series. High Oil Consumption
hi, this consumption seems high, i would take it to a dealer and ask them to check the oil sensor.......
P.S. is there a lot of smoke coming from the exhaust, if so, it may be burning a little oil, ask dealer to check it
SOURCE: BMW 316 leaking oil, about 1 litre every 2 weeks
your going to have to clean it down good with some engine cleaner, then run engine, try to pin down leak. may have a bad oil preasure switch thats leaking, or oil filter, or a gasket; hope this helps good luck.
Testimonial: "Great, thanks"
SOURCE: my toyota tazz (conquest) has a major oil leak. I
you need to replace your top gasket i had the same problem with my tazz the car decided to start over heating and used alot of water so take it away and have it fixed before your problem becomes bigger and i payed R1000 to have my car fixed properly
