Hp laserjet cp3525
SOURCE: HP Laserjet 5200
Hi, Here is a link to the service manual. It is in PDF so might take a couple minutes to open. http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00575070/c00575070.pdf Hope you find what you're looking for. Thanks, Lolita
SOURCE: HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
SOURCE: Service Manual for disassembly
HP Photosmart C7280 printer gets into a paper blockage mode that appears to be from its own mechanical parts - leaving 1.2cm wide indentations on the leading edge of the paper on its top left side starting at about 2 cm and sometimes also 7 cm from the corner. Happens in copy and print modes. Is there a fix for this problem?
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
